On DeckMovable Ballast |
Page <1 23456 7> |
Doug Lord
Joined: 03 Sep 05 Location: United States Online Status: Offline Posts: 66 |
Topic: On DeckMovable BallastPosted: 29 Sep 05 at 2:17pm |
Stefan, I'm afraid it sounds like you use a "what if" question regarding the Backman 21 as a sort of indictment when, if you assume that the boat is designed and built right, the answer is simple: move the keel! That very thing happened to Pyewacket(or Glory?) in Antigua last year and the solution? They moved the keel. Not trying to be wise guy I'm just trying to point out that whether it is a canting keel or on-deck movable ballast system the boat SHOULD be designed to deal with the situations you describe.And as you point out any keelboat is subject to a knockdown. So if the boat is designed well , built right and sailed intelligently there should be no problem. But as you know there are always conditions that can get the best of any boat...
I feel that while questions such as yours SHOULD be asked of every boat they should not be used as an indictment; a presumption of unsuitability unless you are familiar enough with the boat to know that it is NOT designed well or built right... As to my concept of on deck movable ballast it allows for MUCH more RM than a normal canting keel while at the same time providing buoyancy greater than the weight in the wing and -in"safe mode" with a deep ballasted daggerboard is self righting. As I visualize this idea it could conceivably be sailed w/o the ballased board by an able bodied sailor and righted like any other dinghy-though even w/o the weighted board the thing would be almost self righting. The extreme situations you mentioned MUST be taken into account in the design of this boat or it won't work.... And just for the record most of my early, early racing was in a 20' gaff headed keelboat.... |
Stefan Lloyd
Posted: 29 Sep 05 at 2:43pm |
I wrote:"Interesting concept but I wonder what happens if you get knocked down with the keel on the wrong side." That's a question, not an indictment. And sorry but the resemblance between a 20' gaff headed keelboat and something like the Backman seems a bit tenuous. I've owned and skippered sportsboats, helped run a class association and rewrite the class safety requirements, and I have some idea what they are like and what can go wrong. The boat identical to mine which I witnessed sink from close quarters shouldn't have sank but it did. Saying something "should" be OK isn't really all that comforting. |
CurlyBen
Joined: 17 Aug 05 Location: Southampton Online Status: Offline Posts: 539 |
Posted: 01 Oct 05 at 7:12pm |
Another thing to think about is that you're trying to make a high
performance dinghy/skiff - they work on the basis of combining very low
hull weight and large sail area with a decent righting moment. The
RS800 weighs about 10 stone, and presumably your ballast would be a
similar weight. Add one crewman and either you're trying to single hand
a 800 or double up in a 700 (Not sure if that's clear but I'm thinking
of sail area to weight ratio), if you keep the sail area the same. You
could increase the sail area, but then you'd be increasing sheet loads,
and if this might be targeted at disabled sailors you could end up
finding yourself needing winches, and suddenly you're building a
sportsboat. This target market would also mean you wouldn't be able to
use leg power to move or control the ballast. Just a thought.
Phat Bouy
Joined: 15 Jun 05 Location: United Kingdom Online Status: Offline Posts: 168 |
Posted: 01 Oct 05 at 9:37pm |
Dear Lord, you made the night too long for this bouy.
Call me an old fart but if this boat is designed/made for disabled sailors and is superb at self-righting, what happens if it capsizes and the afore-mentioned disabled falls out but know one notices (it does happen) and the boat rights itself and sails on unattended? Please do not give me a long list of "ifs", " buts" and "ands" - get the boat built and demonstrate it to the world. Enough of all this talk, if you are so ssure of your design then it's time for action! |
Doug Lord
Posted: 01 Oct 05 at 10:06pm |
Sorry old boy but it's not time to build yet. Good to know that Bethwaite and Bulloch are using ON DECK MOVABLE BALLAST on their Pterodactyl concept boat(about 65').
I would think that the likelyhood of the crew falling out of this boat would be much less than the crew falling out of a 2.4 meter which ,to my knowledge, has never happened. I guess the model will have to serve as proof of concept for now-and believe me it 'twern't inexpensive to build and test:
Doug Lord
Posted: 01 Oct 05 at 10:17pm |
Heres the article on Pteradactyl(on deck movable ballast + buoyancy pods):
http://www.sailinganarchy.com/fringe/2005/pteradactyl.htm Edited by Doug Lord |
Doug Lord
Posted: 01 Oct 05 at 10:28pm |
And here is the url to the Bethwaite LAS(Lead Assisted Skiff):
Bethwaite Design // Latest News // NEW - UD 18 Skiff sailing for Sailors with disabilities http://www.bethwaite.com/10837,02,2-0--new---ud-18-skiff-sai ling-for-sailors-with-disabilities.html Edited by Doug Lord |
Isis
Posted: 01 Oct 05 at 11:57pm |
The 'pteradactyl' may make use of movable deck balast, but it also
features several able bodied crew, probibly most of them on wires, its
close enough to 5 times as big as your 'concept' and weighs 2 tonnes!!!
Not comparable to a skiff by anyones standards |
Doug Lord
Posted: 02 Oct 05 at 12:45am |
The only(!) thing(s) Pteradactyl and the 17 have in common are on deck movable ballast, buoyancy pods and a ballasted appendage in the water. Interesting any way you look at it.
I've not learned how Bethwaite utilizes the ballast on his LAS but I have learned that apparently Herreshoff had a small boat using a brass ingot or so as on deck movable ballast; I was told it was one of his favorite boats. The more I look into it the more I like the concept and not just for disabled sailors. The boat seems like it could be configured from a high performance dinghy with numbers similar to a 505/FD to even more powerful. Since the ballast in the wing is adjustable and the ballasted board is removable there may be more than one level of performance/excitement achievable with the same basic hull+wing. |
Stefan Lloyd
Posted: 02 Oct 05 at 8:17am |
So, I surmise that all this posting on every sailing board in the known universe is about getting positive responses you can show to people who might give you the money to develop it. Good luck! Deck moveable ballast is a fascinating and promising concept. Signed, A UK Sailor. Hope that helps. Edited by Stefan Lloyd |
Page <1 23456 7> |
