Tomahawk |
Page <12345 11> |
Contender 541
Topic: TomahawkPosted: 06 Mar 09 at 9:04am |
Awesome looking boat Some brilliant photo's too |
Crew on 505 8780 |
Guest
Posted: 06 Mar 09 at 9:34am |
Their website is up now http://www.tomahawkfoils.com/ it was 404 yesterday. Interesting that these foils have no moving parts. |
timnoyce
Posted: 06 Mar 09 at 9:41am |
I am unsure whether it is both foils which have no moving parts, or just the main foil. The tiller looks to be similar to the twist grip on the moth. I hope that they really do have no moving parts as that would aid manufacture, reduce cost and also obviously reduce the chance of gear failure.
Guest
Posted: 06 Mar 09 at 9:43am |
That extension looks too thin to be a twist grip ...
tgruitt
Joined: 02 Dec 04 Online Status: Offline Posts: 2479 |
Posted: 06 Mar 09 at 9:51am |
That main foil looks massive!
Contender 541
Posted: 06 Mar 09 at 10:27am |
Its interesting to see just how short the foils are.
Crew on 505 8780 |
timnoyce
Posted: 06 Mar 09 at 10:35am |
The extension can be any thickness you like to be a twist grip, it's the fitting on the tiller which is the bit you need to look at.
Without reading too much into the couple of photos as I know they aren't really representative of the way the boat is sailed, It seems suprising that heeling the boat to windward and having the foil break the waters surface would be quicker than keeping the boat flat and keeping the foil submerged. I quite like the idea of short foils. Less distance to fall when it goes Pete Tong! |
hum3
Joined: 23 Jun 06 Online Status: Offline Posts: 247 |
Posted: 06 Mar 09 at 10:46am |
Short foils might be less forgiving waves/chop though...
Guest
Posted: 06 Mar 09 at 10:52am |
We'll find out the answers to our questions tomorrow morning .... |
timnoyce
Posted: 06 Mar 09 at 10:53am |
Yes, this is true. Swings and roundabouts I guess. In being lower to the water you may be affected more than being higher up.
I am intrigued to know how the foil knows when you are at the waters surface. The lift generated is affected by speed, so would it potentially porpoise when you get going really quick, or will the drag caused at such high speeds prevent it from going any faster and so stop it from ultimate lift off? So many questions! hmmmm ![]() |
Page <12345 11> |
