Laser 13 rig settings |
Page <123 |
Grumpycat
Joined: 29 Sep 20 Online Status: Offline Posts: 497 |
Topic: Laser 13 rig settingsPosted: 11 Apr 22 at 10:46pm |
The option of a larger/better rudder was put to a class vote sometime in the in late 80s/early 90s ( back when I was a class member ) . It failed and I don’t think this option has been put to the class since .
Edited by Grumpycat - 11 Apr 22 at 10:49pm |
Grumpycat
Posted: 11 Apr 22 at 10:48pm |
So true .
Oatsandbeans
Joined: 19 Sep 05 Location: United Kingdom Online Status: Offline Posts: 382 |
Posted: 12 Apr 22 at 6:07am |
I remember a story about the first IACC America’s Cup. Before race 1between America cubed, and Il Moro de Venezia they both had to remove the skirts to show the world the underwater appendages. When the US designers saw the size of the Italian rudder they realised that one of the designers had got it wrong. The Italian rudder was double the area of the US one. The larger rudder was slow and draggy. The US boat was faster but the sail trimmers had a big input into what the boat was doing-. It is the same for dinghies. |
Guests
Posted: 12 Apr 22 at 6:15am |
I’ve done quite a bit of research and analysis on this. As a first approximation, to minimise drag you want the lift to be shared between the daggerboard and rudder in proportion to the square of their spans. For example if the daggerboard is 1m deep and the rudder is 0.7m deep: 1^2 = 1, 0.7^2 = 0.49, so ratio ~ 2:1 (i.e. the rudder should take one third of the total load). In reality the rudder is surface piercing and in the wash of the daggerboard so the relationship changes a little. In this example, if the rudder is less than one the total foil area then it can only provide one third the total force if angle of attack on the rudder is increased by pulling the tiller towards you. The boat therefore needs to be set up with some weather helm to keep it tracking straight.
Gordon 1430
Joined: 27 Jun 17 Location: Lee on Solent Online Status: Offline Posts: 310 |
Posted: 12 Apr 22 at 7:41am |
The angled rudder on the laser helps no end with rowing in the starting area.
Phantom 1430 |
Oatsandbeans
Posted: 12 Apr 22 at 5:09pm |
Yes -I am sure that’s why Bruce did it-(can’t think of any other good reason for it!)
423zero
Posted: 12 Apr 22 at 6:50pm |
Probably already had the rudder from another boat. Not forgetting he didn't design it to be the racer it became, designed to carry two people and was going to be called the Weekender.
Edited by 423zero - 13 Apr 22 at 6:06am |
Robert
Sam.Spoons
Posted: 13 Apr 22 at 11:13am |
More likely that a 'swept back' rudder blade would look racier in the eyes of a non sailor.
423zero
Posted: 13 Apr 22 at 12:20pm |
Should have gone for stripes and a matt black foredeck
![]() Edited by 423zero - 13 Apr 22 at 7:14pm |
Robert
Page <123 |
