Start line colision |
Page <123 |
| Author | |||||
Topic: Start line colisionPosted: 04 Aug 15 at 10:06am |
Just not true though. Three possibilities. You overtake from behind and to windward. You are keep clear boat. You overtake from directly behind and to leeward. You have right of way but may not sail above *your* proper course, and must initially give the other boat room to keep clear. You overtake from behind and well to leeward. You have right of way and no restrictions on your course. In paper/electronic rules discussions there is a lot of virtue in quoting rule numbers because it defines which rules you believe apply, and saves quoting the entire text of every rule all the time. In an on line discussion the rule book is always available to all the participants. By contrast on the water quoting numbers is not usually very useful. Edited by JimC - 04 Aug 15 at 12:24pm |
Presuming Ed
Joined: 26 Feb 05 Location: United Kingdom Online Status: Offline Posts: 641 |
Posted: 04 Aug 15 at 11:08am |
In my umpire seminar, John Doerr asked us a question: "do you need contact to prove that you're not keeping clear?" and, of course, we all immediately said "no, of course not". At which point he asked "what about 12? Wouldn't you feel a bit aggrieved if you were binned for not keeping clear if there wasn't contact?" At which point, we all agreed with him again. Getting that close is very high risk for the trailing boat. & it's also (arguably) less useful if you're trying to control the boat ahead than being a bit further back so that you can always get on the inside of any turn. |
Posted: 04 Aug 15 at 12:03pm |
Take my IC, which has an underslung rudder and a pointed stern. If we get too literal about this if a boat coming from behind makes contact 5mm to leeward of the point then I failed to keep clear of her under RRS11*. If she makes contact 5mm to windward of the point then she failed to keep clear of me under RRS11. Only if she makes contact *exactly* on the very tip of the stern would it be a breach of RRS12. Obviously that's a nonsense.
So there must be a zone around a boat that constitutes not keeping clear, and it must be variable depending on boat and conditions. If you want another situation where being excessively literal starts becoming a nonsense, consider if my canoe makes contact with the leeward side of the windward hull of a catamaran.
Taking that example: people might be aggrieved if DSQd with no contact under RRS 12, but they shouldn't be. However sometimes you know that a rule has been broken, even if you can't define exactly when. Take my example above of the boat that contacts the stern of my IC 5mm to leeward of the point. Do you penalise me under RRS 11, or do you penalise the other boat under RRS12 on the grounds that although you can't be precise about exactly when he failed to keep clear under RRS12, he can't have got in that position without breaking it? *yeah, OK room to keep clear comes into it, but not the point at issue Edited by JimC - 04 Aug 15 at 1:01pm |
Presuming Ed
Posted: 04 Aug 15 at 2:29pm |
LTaking your catamaran example, there is a degree of ambiguity there, which is why in the AC rules they clarified it - as between the hulls is clear astern. And with you IC, what about 30 cm either side? Or 60?
The "wiggle room" requirement only applies to boats on the same tack and overlapped. For ISAF case 50 to apply to port/starboard crossings, starboard has to alter course. If s holds her course, and p crosses, then you can't apply 50. No matter how close. If, however, in a CA/CAstern situation, Ahead said that they had to alter course to avoid contact, and the boats were gnats wing close, then under 50, astern isn't looking rosy. But if ahead holds her course, then astern is keeping clear. In the RYA appeals committee, there are 2 factions (AIUI. I'm not a member). One of "sailors", and one of "lawyers ". The sailors just go " you can't ram people up the chuff" and just leave it at that.
Edited by Presuming Ed - 04 Aug 15 at 2:32pm |
Rupert
Posted: 04 Aug 15 at 8:00pm |
"You can't ram people up the chuff" sums things up nicely, thank you!
SoggyBadger
Joined: 26 Oct 10 Location: The Wild Wood Online Status: Offline Posts: 552 |
Posted: 04 Aug 15 at 8:04pm |
Apparently they don't like it up em ![]() |
SB |
Brass
Posted: 05 Aug 15 at 12:50am |
Brass
Posted: 05 Aug 15 at 1:07am |
Page <123 |
