Laser 161752 Tynemouth |
Another blown trailer tyre |
Page <123 |
![]() ![]() ![]() ![]() Posted: 27 Nov 14 at 10:02pm |
Oh yeah - my recommendation is to carry too torque wrenches - one to turn it, one to hold the wheel, which may not have enough weight to stop it rotating once flat/blown out.
Update: I took the trailer to Guildford Trailer Centre for an opinion. It was interesting. Their conclusion was simply under-inflation. The standard 4ply tyres should be inflated to around 60, yes 60 PSI, probably twice what we all run.
They talked me out of 10 inch wheels for now, but I now have some hopefully decent 6-ply tyres (PSI suggestion, up to 80!!) First trip away looms, be interesting to see if I get to the Rutland Sprints and POSH and back without using the spare
Edited by fab100 - 05 Apr 15 at 8:00am |
Sounds like a good way of wrecking the boat to me. The weights that we tow are so low that the suspension units dont really work properly. therefore you need slightly soft tyres to cushion the boat a bit. on 8 inch wheels i run 30 psi, usually slightly less on the 10 inch. I accept this may be why my trailer ate the 8 inch tyres, but there is no way I would run anything like that kind of pressure the trailer would bounce all over the place.
To a large part this comes down to mindset and us being cheapskates, manufactures will understandably build & equip down to a price we want to pay and meet the legislation in place at the time.
From what I have seen of our continental cousins they have far better (heavier) trailers often equipped with 13 inch wheels and much more convincing suspension units. How much this has been created by more stringent legislation or a mindset for engineering I cannot say. Thinking about the recent new generation of light boats, the temptation could be to say you could use even lighter trailers. Being someone who will often use a six inch nail when a four inch would do. I would say, go more mass rather than less in the trailers to work the suspension and give the boat an easier ride. |
The bottom of the range indespension units are only rated 125kg max... Boat and trailer is going to be well within working range for that. It would be nice though if there were a more sophisticated longer travel alternative readily available for boat trailer suspension.
Edited by JimC - 06 Apr 15 at 1:53pm |
Yes Jim, you're not wrong but perfect matching seldom seen in practice though.
As you say longer travel would good, those rubber compression units never seem to move far and if they do move there is no rebound control. Are there not any self contained torsion beam axles available? From the dim and distant I have a recollection of seeing a swing arm supported by a combined coil spring and shock absorber unit.
Yeah, I've got a veteran trailer with that seTup. Consider tho, retail for a pair of indespensions about 40 qui, and they're dead easy to fit, just bolt on a cross beam. A pair of aftermarket bike shocks are around 80QUID, then you've got to fabricate some sort of swing arm, weld on top and bottom anchors etc. At least a hundred quid on the price of a trailer, maybe 200. Are people going to pay?
tickel ![]() Far too distracted from work ![]() ![]() Joined: 21 Dec 05 Location: United Kingdom Online Status: Offline Posts: 408 |
The best trailer I ever towed had a transverse leaf spring with the hubs attached to the ends off the spring.
All it needed was two little dampers to make it perfect. |
tickel
Blackie ![]() Groupie ![]() Joined: 03 Jan 08 Location: United Kingdom Online Status: Offline Posts: 48 |
I've just (about a year ago) taken over the helm at Vandercraft Trailers (now Admiral)and I think I probably agree with most of the comments.
Wheels/Tyres, yup chinese built to a price. Saying that we have very few problems with them. Even the 4 ply have a load capacity of 550kg (road bases are 500kg generally) BUT it does depend on using the correct inflation pressure. 10in wheels and tyres do give a much better ride and if changing from 8in the mudguard and bracket will need changing. We fit a radial 145R10. Most combi's now are built with a solid beam axle and I've never come across a situation where the hubs aren't in line. However it is possible and worth checking if the tyres are wearing out quickly. We have had an instant on a pair of independant units where one of the swings arms hadn't been welded on square resulting in one of the hubs having excessive toe in. Axles. There are axles and there are axles... We use the Alko one which is the funny looking triangular ish tube... Although rated at 500kg, (they tell us!) that because of the shape of the tube and having only 3 bits of rubber in there that they have a soft initial bump. Ideal for lighter boats. That's in comparison with a square tube normally found on independent units and some beam axles. The other thing about axles/independent units is that despite some of them being rated at lower weight limits quite often they are exactly the same as higher rated units. So if a company make a 500kg unit they may also make a 300 or 350kg unit. Often the 300/350 kg unit is exactly the same. ie 500kg... Just badged differently. You have to remember that us dinghy sailing folk are in a minority here looking for lighter suspension to look after our boats whilst most of the trailer using public want suspension that while take as much load as possible. Lighting boards. Yup cheap and cheerful, although with the advent of type approval most manufacturers are moving to heavy duty boards with one piece combination lights on them. I have no idea why they are twice the price though!!! And you would have thought leds would be cheaper to make that bulbed fittings but again double the price and you'd be somewhere close..! |
B14 - 764 Admiral Trailers
Page <123 |
