RS400 proposed changes |
Page <1 2122232425 29> |
| Author | ||
Hornet
Topic: RS400 proposed changesPosted: 06 Nov 12 at 10:50pm |
Tink you will find a lot of the top of the fleet are more comftable competing with the old style main than the new ! Addmitted the have been a nameless few that swap thier sails on windy day then revert to the new ones on the following day! Talk about can of worms!
As for the pole was it not meant to be carbon when they proposed the changes? Either way its a load of rubbish if you have a spare ally one i reckon the value will go up shortly! Accept the points made about the boom to some degree but thats a personal view point! Did the boat really need modernising?? I am just annoyed as this was rushed through without much engineering or testing as proven by the pole failures and the fact i was a CA member and didnt even get a voting form!
Jamesd
Joined: 01 Feb 08 Online Status: Offline Posts: 377 |
Posted: 07 Nov 12 at 9:27am |
Trust me, every effort was made to get voting forms out to all CA members. there were notices emailed, posted and advertised. If you missed it, then it can only be your fault.....bar hunting you down and ramming a form down your throat, there was little else the class could do.
Did the boat need modernizing?? Yes, if you went to the boat show 3 years ago, the two most dated looking boats were the 2 and 4 and thats compared to boats 80 years old. The sailcloth used for the old mains is pretty much only used for them the 2s and the 6. its expensive, it is a more sustainable move, to use a modern material plus the cost of a main dropped £100 None of the top boats are more comfortable using the old style sails, the top 3 certainly didnt use them at the Nats. I prefer the new sails, I have an old main used one week only, id sell it if someone wants it. People change sails because there is a loop hole in the rules, the people that change don't do any better do they? Did speccy change? did stewart or jim change sails? no, they used the same set of new style sails all week and do for each event and funnily enough they are at the top of each event. Now where's your evidence to back this up? A whole load of engineering and time went into the development of the 400. RS spent a fortune in materials and labour, sailors gave up days and days to help with the development, it was not rushed through i can assure you that! The pole has a few issues still, are RS denying it? no! ring them up with a fault and they help and replace the pole, its development! Things are never right first time round, fatigue doesnt happen over night, an engineer knows the process of design and its evolution.....you sir do not!
alstorer
Posted: 07 Nov 12 at 10:14am |
Without such a rule, there's no can of worms- it is allowed. Plain and simple.
Al |
Kev M
Joined: 05 Dec 11 Location: Landlocked Online Status: Offline Posts: 346 |
Posted: 07 Nov 12 at 10:22am |
And a good engineer knows that a product shouldn't be released to market until it has been thoroughly tested. Products should be adequately tested before expecting paying members of the public to do the beta testing. It's far more expensive for a company to keep replacing faulty goods than to test the thing properly in the first place before selling it to its customers. The only reason companies don't test their products properly is because most don't have the balls to tell their customers to wait, because customers are so used to having instant gratification. |
Rupert
Posted: 07 Nov 12 at 10:29am |
I've sometimes swapped sails on a windy day - not as the move of a front end sailor, but in order not to destroy a new sail which I can't afford to replace. Top sailors might do this too, I guess.
But, as Al says, a lot of classes only allow one set of sails at an event, barring damage. Up to the class what they allow, really. |
Jamesd
Posted: 07 Nov 12 at 10:39am |
in practice this doesn't work. we are not talking about a car you can stick on a rolling road for weeks. You can run FEAs and run calcs on a pole which in effect is a cantilever, but used in an ever changing environment which sailing provides, you cannot test for everything. Also I know RS have a problem where they get little feedback from customers, If one pole breaks, they may have been abusing it, if 10 poles break there is clearly a design issue. the problem they have is those ten people throw the pole away, say its sh*t and get the ali one out.
Remember RS are only customers like everyone else. They purchase something they have been told will work. A few break, but i'm confident selden will get it right next time round.
Jamesd
Posted: 07 Nov 12 at 10:41am |
The rules there, its just worded in such a way that the only time you need to gain permission to change a sail is when its damaged, if you want to change sail any other time you are more than welcome without permission. Just badly written, need re wording.......or at least that was the rule last year
Kev M
Posted: 07 Nov 12 at 11:13am |
You're right, a car has millions of components to test, we're talking about a single pole. Regardless of who manufactures it, it seems they didn't test it enough and it doesn't matter if RS are the customer, they're the ones putting their name to it. Would it really have been beyond the realms of RS or Selden to have given a selection of customers the product to test for a year in all conditions before releasing it to market? I'm sure the CA would have had plenty of people who would rather have tested a product before release than be paying for it and testing it after release. |
maxibuddah
Posted: 07 Nov 12 at 11:21am |
A similar thing happened with early selden phantom masts. They broke at the gooseneck, they replaced them once the problem was identified they amended the design. Hasn't happened since. Trouble is they and the class got a reputation for dodgy masts and it would seem that it affected insurance premiums even though selden repaired every one of them.
With the best will in the world theoretical analysis will only tell you so much, only practice with a real item in real situations will prove it. |
jeffers
Posted: 07 Nov 12 at 11:55am |
I thought you were supposed to use the same set of sails for a given event. Most SIs cover this already and state you must seek permission from the RO to change (this is then posted to the official noticeboard for championships). It is a little petty though IMO. To be honest I would switch to an old sail if was blowing old boots then back to a new one when it went lighter if the SIs allowed me to. For most championships you are only allowed to switch sails or force majeur (i.e. down to damage).
