Laser hiking bench |
Page <12 |
Cameron Winton ![]() Groupie ![]() Joined: 08 Nov 11 Location: Prestwick Online Status: Offline Posts: 41 |
![]() ![]() ![]() ![]() Posted: 28 May 12 at 11:49am |
I would advocate getting out and sailing. I am back to sailing after 25 years, reasonably fit (Long term runner, 5-a-sides, cycling to work) and at the start of the season found my thighs suffering seriously for a few days after each decent length sail. Now finding the legs a lot better although yesterday's light airs found me scrunched up at the centreboard and my right knee locked up twice!
Sailing is better generally, but we can't all go sailing every day.
I'm thinking of knocking up a hiking bench for a couple of reasons: 1) we can go for weeks with not much hiking, then have a 2 mile beat in F5. 2) It would allow me and crew to play around with toestrap settings in a constant environment, and check the settings we come up with are the most useful for constant hiking. Normally, I race thinking about other things than 'are the toestraps right' until it becomes really obvious they are badly wrong. When I'm trying to hike out extra hard in a gust, I usually have a lot else to do than think about whether the crew's straps should be longer or just moved outboard a bit. I guess on a Laser there is only one variable though. |
deadrock ![]() Groupie ![]() Joined: 24 Jun 08 Location: United Kingdom Online Status: Offline Posts: 85 |
bustinben ![]() Far too distracted from work ![]() Joined: 15 Oct 06 Online Status: Offline Posts: 288 |
I do quite an extreme amount of cycling, and it just doesn't translate. If you had no leg fitness at all, then it probably would help, but if you're already fit and you want to be able to hike hard for 20 minutes at a time, you need to train the kind of static/hold strength that hiking requires. Cycling is dynamic. You also need to work your abs. Hiking bench is exactly what you need! If you have bad posture or technique, then you'll injure yourself. Same as you will if you have bad posture on the bike, or when you're doing weights. If I could sail for three hours a day then I would, but I can't, so rather than losing both technique AND fitness, the bench allows me to just lose technique :P |
Ginge ![]() Posting king ![]() Joined: 28 Dec 11 Location: Isle Of Axholme, Doncaster Online Status: Offline Posts: 117 |
That's what I'm planning on using. I just want one as hiking is the only way of replicating hiking, as you can't always be sailing |
Laser
winner ![]() Newbie ![]() Joined: 25 Mar 12 Online Status: Offline Posts: 16 |
I made a hiking bench for a finn and ok dinghy mixed a couple of months back using the deadrock design but just changed the height and deck width and shape to be like the finn and ok sidedecks. Works really well and has helped my hiking style and in-durance alot, you would need to use it for about an hour a week at least to get the best from it, also a good thing is to implicate your wave technique where you move your weight onto your back leg and hike harder up the wave and at the crest and move it back to both legs on the way down. Also a good thing to do is to rig up a rope with resistance similar to a loaded up main and replicate sheeting in and going to the hiking position, i found this really helped with boat handling on the start line and with mark roundings, furthermore it also helped build up the strength in my hands,wrists and arms. Good luck with the build as they are worth it, if you use it enough.
Page <12 |
