RS600 Boom? |
Page <12 |
![]() ![]() ![]() ![]() Posted: 09 Jun 08 at 10:27pm |
going outside the boom means going right around 2 bloody great jaws the get bolted onto the mast. this would shred the block as it went past the jaws. Im not sure what the problem with the old boom is, i have a spare old boom that has hairline cracks around the rivets where the mainsheet blocks are tied to so i dont use it, but the jaws on that seem to be pretty much the same as on my new boom. |
Also International 14, 1318 |
why not just rig it outside the boom then? im sure you only want to let it right off in the lighter stuff so the extra friction pulling it on shouldnt be a problem. or am i missing something here?
Landlocked in Africa
Splosh ![]() Far too distracted from work ![]() ![]() Joined: 13 May 07 Location: United Kingdom Online Status: Offline Posts: 497 |
Ok, I'll have a look at the rope with the knot on tomorrow as you make sense and it just could be that! Thanks. |
RS300 - 346 :D
Mark,
I dont understand why you have a problem with your boom. My 600 had the old boom and I never had any problems. When you tie the end of the cunningham off on the boom (knot in the slot), then with the cunningham let right off in the cleats the block should be just inside the bottom of the boom jaws. This should give you just enough travel to get the tack down far enough in the windy stuff. Alternatively have a lightwind knot and a windy knot. If its good and breezy you wont be letting the cunningham off that much anyway. Paul |
Hi, My 600 still has a old style boom on it and i struggle to pull enough cunni on because it can't pass through the boom when eased/off (like on the newer style ones). Does anyone have one lying around and willing to part with? If not, would it be wise to cut the gap bigger on mine? I doubt it, because it doesn't look as reinforced as the new ones, and would probably not be covered under insurance if i do. Any help? Thanks, Mark. |
RS300 - 346 :D
Page <12 |
