B14 single handed? |
Page <12 |
![]() ![]() ![]() ![]() Posted: 16 Nov 06 at 6:36pm |
I would say the buzz singlehanded is good fun, get a telescopic extension, and you'll be fine on the wire. I'm about 14st with a lighter crew, and sailing singlehanded is not much of a problem unless it gets above a strong 4.
Jp Indoe
13 stone is a good weight for boats like the 600, MPS, etc as TT mentioned. Either go for a double-hander, with a consistant crew, like the B14 or go for something like a 600, Contender, etc. As Dave mentioned, the B14 will be totally unbalanced to sail with just the main and very difficult, 600 would be much nicer and quicker round the course.
What is your budget?? Im sure you'd be able to pick up the likes of BOTH a B14 and an RS600 quite cheap.
porkyman ![]() Newbie ![]() ![]() Joined: 13 Nov 06 Online Status: Offline Posts: 27 |
thanks for the physics lesson english dave. perhaps my lack of understanding of these technical issues explains why I have never won any races. I am still a little confused. i used to sail a Dart 18 without the jib [single handed]as is the norm for the class. i could tack the dart with no jib,{most of the time], and cats can be a bugger to tack even with the jib up. so how come a mono hull with no jib will be a problem.
Doug, my budget is only about £1750, so two boats is not on option. my money i know will have to a long way |
porkyman
Dart 18's have long skegs, do moving the centre of effort has less effect on the centre of lateral resistance. With a daggerboard, things become more critical, and a tiny movement of Cof E can throw the balance out. Even too much or too little mast rake will feel strange.
bernie ![]() Newbie ![]() ![]() Joined: 11 Oct 06 Location: United States Online Status: Offline Posts: 24 |
Forget the idea of a B14. You won't be able to sail it with just the main, and it'll be close to impossible with the jib on too. The jib on a B is quite powerful and if you try to "cleat it and leave it", it'll have you in the piss before you know it. An old-rules single-trapeze Cherub can be a right laugh single-handed and two-up in a blow it'll carry your weight and it won't hang around. Have fun... |
Never sheet out.
Page <12 |
