New Posts New Posts RSS Feed: Solo techniques.
Solo techniques.
Paramedic View Drop Down
Post Options Post Options   Quote Paramedic Quote  Post ReplyReply Direct Link To This Post Topic: Solo techniques.
    Posted: 10 Jul 20 at 9:26pm
David have you ever used a cumulus?
I ask as I thought exactly the same as you, I had a new winder 2, D+ etc etc and sold it as its was second boat and replaced it with a much older mk1 which i've restored from a bit of a wreck. If anything I think the  2000AD Mk1/Cumulus/Milanes foils is faster. Its feels much, much smoother. And I wasn't slow in the mk2.
Edited by Paramedic - 10 Jul 20 at 9:27pm
davidyacht View Drop Down
Post Options Post Options   Quote davidyacht Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 20 at 7:32am
Yes, had two Winder 1 Solos with Cumulus (side weld) and Milanes board, and a selection of North SM8 and Hunt sails.  Bearing in mind we are discussing pretty small differences in a one design class, here are some thoughts.
I now sail a Winder 2, I think it is marginally easier to sail than a Winder 1.  With more rocker it is easier to tack.  The Winder 1 seems to plane marginally earlier.
The Cumulus is probably as good if not better than the D+ rig in F0 - F3.  It is stiffer and is good for heavyweights.  The set up is quite different as it doesn’t respond to sailing with the traveller down in the same way as the D+ rig, so one tends to sail with a bit more twist.  My reservation about the Cumulus is that because it is so stiff fore and aft I reached a point (I am 83kg) where it seemed impossible to de power and it had poor gust response.
Also the side weld Cumulus required a different cut sail, then to go this route is to carve a lonely furrow.
However if you are heavier, and sail on sheltered flat water the Cumulus might have more going for it in my opinion.
I have no idea how the more recent front taper Cumulus masts perform.
Happily living in the past
Post Options Post Options   Quote Paramedic Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 20 at 8:30am
Interesting...........
Mine is a side tapered mast, possibly original to the boat.
I'm a bit heavier (certainly post lockdown!), and I am sailing on sheltered flat water. I put a lot of the different "feel" of the boat down to the board. The other thing that stuck enemy mind was that a "stiff" cumulus is almost as stiff as an Alto according to some GP and Fireball sailors so I wondered if a "soft" one might be about the same as a D+, though on paper the numbers are the same.
Downgrading the boat was a real sticking point and I wasn't keen on doing it, but apart from the smoother feel I haven't noticed a significant difference - though it must be pointed out that i've yet to race it properly.
Edited by Paramedic - 11 Jul 20 at 8:35am
Post Options Post Options   Quote davidyacht Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 20 at 9:58am
As if a bar chat ... I would suggest that you probably tick some of the boxes as to why the Cumulus would be a good mast for you.  I had a Milanes “flexi tip” centreboard which seemed quite special on three boats back ... I should have kept it!
