Solo Opinions? |
Page <1234> |
![]() ![]() ![]() ![]() Posted: 21 Feb 19 at 12:31pm |
That's arguably the worst of both worlds. Pre foam sandwich GRP is without any doubt the worst material to build a Solo from, that's why wood boats kept on being popular for so long, and wood decks mean you stil have to maintain, keep out of the frost etc. Edited by JimC - 21 Feb 19 at 12:31pm |
NickM99 ![]() Posting king ![]() Joined: 26 Apr 14 Online Status: Offline Posts: 145 |
JimC is quite right. If you would consider a GRP boat with a wooden deck, why not an all wood boat? There are three advertised currently on the Solo Association website and at least one of them has been epoxied from new. They are less than half the price of FRP boats and will be competitive for club sailing if the rig is right for you.
Late starter ![]() Far too distracted from work ![]() Joined: 24 Feb 07 Online Status: Offline Posts: 481 |
I've not sailed a Solo for a long time so I'm not up to date with developments in the class, but I sailed a GRP/composite boat for a season probably 10 or so years back. I found this very slow, and a pal of mine who also had a similar boat at the same time was also very slow. We were sailing against some of our pals who had modern FRP ships, and the difference in speed was very marked. And these were guys who I'd sailed against for years in Lasers, Phantoms etc and we'd been broadly similar in ability. JimC and Nick are right, if I wanted an inexpensive Solo I'd buy a wooden boat from a decent builder with the right rig.
Around the lake, you won't find a lot of difference between a recent wood boat and a from one.
Look for a well setup Boon/Gosling. O viously, it should be sound and as down to weight as possible (mine carries 3kg of lead). Check the mast for your weight (Solo website), and that the sail matches the mast bend! Also, the mast rake makes a significant difference. You may want to look for continuous control lines as well Colin |
On our reservoir I saw about a 5% improvement in performance when someone upgraded from a good modern wooden boat to foam sandwich. I was staggered, I never would have anticipated such a big differential.
KazRob ![]() Far too distracted from work ![]() ![]() Joined: 22 Oct 16 Location: Scotland Online Status: Offline Posts: 245 |
That is a huge difference! At the extremes of that difference that's either the new boats being as fast as a Laser (1148 -> 1090 for -5%) or the old ones as slow as a Laser 4.7 (1148->1205 for +5%). Must be something like Godwin's law where all online sailing threads end up on PY eventually :-)
OK 2249
D-1 138 |
Fatboi ![]() Posting king ![]() Joined: 09 Aug 16 Location: Hampshire Online Status: Offline Posts: 189 |
Not quite true about the performance. The guy who was 11th at the nationals last year sailed a composite boat that is probably 10-12 years old. He had an old wavelength rig and edge sail. Not what you would consider top gear but with 3 results in the top 10 you cannot say it held back too much!
I suspect someone buying a new or recent FRP boat will probably sail more frequently, concentrate harder and likely spend some time practicing so part (most?) of his improved performance will come from that.
The first wave of FRP boats is around that age now. They came as composites as well as there is one at my local club. It still can't keep pace with the current generation though.
Surely there cannot be a 5% difference in actual boat speed
Far more likely that a tiny percentage (1% ?) multiplies itself as you get left behind, in dirty air etc etc 5% boat speed would indeed be a different class of dinghy altogether |
Page <1234> |
