Rigging question. |
Page <1234> |
![]() ![]() ![]() ![]() Posted: 27 Jan 19 at 7:40pm |
It really doesn't matter where you sheet it, for the same sheet load you'll have the same amount of rope. Try modelling it with string and you'll see what I mean. 2:1 end of boom, 4:1 mid boom, it's the same amount of string.
The 4to1 system I have on at the moment is attached a quarter of the way along boom from mast, the mainsheet is very short, hardly any mainsheet to speak of when going upwind, this is why I thought mixing existing 4to1 with a feed along boom and down to a traveller would reduce amount of rope in cockpit compared to 'Laser' set up.
Will follow advice and experiment with both systems.
You might just about get away with bridle to boom, without a purchase. We used that on Cherubs back in the 80s, but on the Moth I felt I needed the extra. I tried a lot of options. Another possibility might be to move the bridle forward a bit. It doesn't necessarily have to be right at the stern.
Tiller is quite long, so could certainly be moved forward, will have a look.
Standard aft main works fine with the Minisprint. I expect you have used it on the Enterprise?
Oddly, I'm thinking if going the opposite route on Minim,putting a 4:1 behind the dagger board case. Thinking about a dagger rudder, which would be easily caught on an aft main. Would a boom made from a Mirror mast be strong enough? |
Moving the bridle forward might mean you'll be sitting on it (which is much more uncomfortable than you might expect) offwind in extreme conditions.
If your existing 4:1 is only 25% back from the mast it is roughly equivalent to 1:1 off the back of the boom. the 3:1 centre plus 1:1 aft setup in your drawing will increase both the purchase and the mainsheet working length by 1.75 (so nearly twice the rope) but will significantly reduce the sheet loads. Using a 2:1 at the back minimises the number of blocks and is more efficient but you would end up with even more rope. Maybe it is worth trying a sort of semi-centre mainsheet with the take off and bridle a bit forward? But if you could get used to off the boom then a ratchet at halfway along the boom and a 1:1 at the back would give you 1.5:1 which might be the best compromise (and only two friction inducing blocks).
Edited by Sam.Spoons - 27 Jan 19 at 8:40pm |
Rupert,
I used a 'Skipper mast. |
I've always hated aft mainsheets (which were almost de-riguer when I started sailing, the OK with a centre mainsheet was pretty modern back then).
Seems to depend upon what you grew up with. As a Firefly sailor, I had to spend time learning centre main when I converted my British Moth in the 90s. Each has its benefits, and there is no intrinsic speed difference.
Me too, I can't get the hang of it at all.
Page <1234> |
