New Posts New Posts RSS Feed: Repairing rudder chips
Sam.Spoons View Drop Down
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Topic: Repairing rudder chips
    Posted: 23 Aug 18 at 9:53am
Plastic Padding type car filler is easier to work than gel coat filler but is greeny-grey colour.
IMHO the best book for the club sailor is Eric Twiname's "Start To Win" but "Club Sailor - From Back To Front" by Clive Eplett covers much of the same ground in a similarly down to earth style.
Pierre View Drop Down
Post Options Post Options   Quote Pierre Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 18 at 9:28am
Yup... gel coat and parcel tape. Works a treat.
PeterG View Drop Down
Post Options Post Options   Quote PeterG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 18 at 8:33am
Yes, gel coat filler is the answer, and easy - but should you perhaps leave them - so you do have something to blame your results on  Wink
Or follow GRF's unusually good advice!
Peter
Ex Cont 707
Ex Laser 189635
DY 59
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 18 at 6:49am
Do both. Those chips are cheap to mend, using gelcoat filler or even car body filler, and psychologically will help massively, as at the same time sand and polish the blade. You start to get more in tune with your boat, at one with the wind shifts, you become an upwind god. Then you hit a patch of weed and come crashing back down to earth. Nice while it lasts!
Edited by Rupert - 23 Aug 18 at 6:49am
Post Options Post Options   Quote iGRF Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 18 at 10:10pm
You could try white gel coat repair and use sellotape to contain it, then rub it down afterwards. A better investment however would be a book on racing tactics, those chips won't do anything compared to a bad start.
Edited by iGRF - 22 Aug 18 at 10:10pm
stonefish View Drop Down
Post Options Post Options   Quote stonefish Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 18 at 9:28pm
Hi,
Whats the best way to repair small chips around the edge of a dinghy rudder, in this case a Solo rudder?  Obviously it's not going to make a massive difference to performance but it will be one less thing I can blame my poor results on  Big smile
Thanks.
