Gybing Technique |
Page <123> |
Ardea ![]() Groupie ![]() Joined: 06 Oct 15 Online Status: Offline Posts: 70 |
![]() ![]() ![]() ![]() Posted: 24 May 16 at 12:21pm |
In double handers in survival weather have the crew attempt to hold the boom in the centre of the boat as it comes over for a fraction of a second. This stalls the momentum of the boom as it comes across and might set the sail on the new side. It seems to break up the rhythm of several things which can all load up at once and cause the big unsettling lurch which usually is the start of the broach or capsize.
I've never had to do it in a single hander, just try to keep speed up and the boom out of the water.
fleaberto ![]() Far too distracted from work ![]() Joined: 12 Jan 09 Location: United Kingdom Online Status: Offline Posts: 302 |
Go fast. Grab falls. Close eyes. Feel for water on face.
No water? - excellent, well done! |
iiiiticki ![]() Far too distracted from work ![]() Joined: 06 Mar 16 Location: Derbyshire Online Status: Offline Posts: 206 |
I always think the danger point is as you start to turn into the gybe and are sailing by the lee, a slight wind shift....After the gybe you can let it go all floppy then collect it up later. Provided you have retained the top of your skull that is. We used to love gybing the Tasar, nice short boom whacks across and a good tug on the jib picks up the power.
Minisprint gybes like it's on rails, any wind speed.
Enterprise gybes ok. Aquabat will try to pitchpole in any decent wind, never found a successful method. None of other boats I have sailed over the years have come close to Minisprint. I could not give you a method for how I prepare for the gybe though, I just go for it, if their is room I will go past mark and tack (if very windy).
In the Solo, a strong hold of the tiller, to ensure that you come out of the gybe pointing downhill, some backward sweep on the plate to give some directional stability, don't be over kickered, gybe at maximum speed ... Don't slow down in the gybe. Reach for reach gybes may offer a better chance of survival, particularly if you ease the kicker a bit. Leave plenty of room at the gybe mark so you are not forced into the gybe while trying to negotiate capsized boats.
Happily living in the past
I've turned into a ditherer as I've got older, sadly.
Makes sense. Confidence is key, dithering is doom. Some days I'm one and some days I'm t'other.
Riv ![]() Far too distracted from work ![]() Joined: 23 Nov 13 Location: South Devon Online Status: Offline Posts: 353 |
My gybing got a lot better after I started sailing a board.
Suddenly the Laser wasn't something I sat down on but something that could be thrown around played with. It's a change of perspective which can be useful at times. |
Leave enough board to stand on.
jaydub ![]() Far too distracted from work ![]() Joined: 06 Jan 07 Online Status: Offline Posts: 267 |
Max speed, keep hold of the gybing strop as the main goes over and a minimal S to stop the boat screwing around. The windier it is the more dead down wind I try and bring it out the gybe. Better to survive and take a few seconds heat it up than to go for it gung ho and wipe out.
Works for me, but I wouldn't call myself an expert.
Page <123> |
