New Posts New Posts RSS Feed: First singlehanded trapeze skiff
loloma View Drop Down
Post Options Post Options   Quote loloma Quote  Post ReplyReply Direct Link To This Post Topic: First singlehanded trapeze skiff
    Posted: 22 Feb 16 at 3:54pm
A Blaze with trapeze ?
turnturtle View Drop Down
Post Options Post Options   Quote turnturtle Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 16 at 2:50pm
or an older A-Class or a Shadow Cat.  The A in particular will be a lot of boat for the money, just don't expect it to be competitive against the new foilers and probably best not get too bogged down in the class politics right now either.
Jack Sparrow View Drop Down
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 16 at 2:14pm
18yrs old, 6'3 and about 70kgs...
...a 3.7 probably would not be appropriate in the long term as you are more than likely to get quite a bit heavier? But if your family genetics mean you will stay at that weight a 3.7 could be a good choice.
For £3k you could get a 3.7 purchase and imported. This one is £1150 + import would be about £500?
Other than that what the other post have said is pretty accurate. You are unlikely to get a MPS for £3K. So your choices are RS700, Contender or if you want to go left field a Vortex.
laser193713 View Drop Down
Post Options Post Options   Quote laser193713 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 16 at 9:21am
The 700 is an awesome boat to sail, people knock it for not being as good as the MPS. I don't think that is entirely the case having sailed both, but they are definitely very different.  The MPS is quite nimble and responsive, certainly well refined. The 700 on the other hand is a real muscle boat, its got loads of power, it's certainly not agricultural but it is less nimble than the MPS. Both are great fun, but they are different characters. Think refined italian supercar vs a corvette. Both will do a quarter mile very fast, the italian might edge it in the corners but the yank in the corvette will certainly be having a blast and might even be faster on the straights.
2547 View Drop Down
Post Options Post Options   Quote 2547 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 16 at 8:02am
Originally posted by gordon1277
Just be aware you may struggle to sell a 600 again and may drop a bit of money on it to move on.
Good advice there ....the 600 isn't really a class as such anymore, as there is no active association. It is a design.
You may struggle to sell when you realise you want some proper racing.
gordon1277 View Drop Down
Post Options Post Options   Quote gordon1277 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 16 at 9:21am
Lossc
RS400atC View Drop Down
Post Options Post Options   Quote RS400atC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 16 at 6:09pm
Also think about what is sailed near you, or what offers opportunities to sail with others of the same class, class coaching etc.
For similar money, you could be looking at an entry level RS800, which IMHO is more accessible and a lot of fun.
craiggo View Drop Down
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 16 at 2:33pm
Biggest issue on 600s is the back of the daggerboard case, foil and the kicker U-bolt.
Daggerboard case and foils are easy fixes, kicker u-bolt is a bigger job.
If there is any play in the kicker U-bolt it suggests that the ply backer has got soft. If there isnt a hatch in the back of the bulkhead then it hasnt been repaired before. If there is a hatch then it has but at least future repairs wont be as costly.
Make sure that the mast has been looked after. If the previous owner has let the varnish peel and has left it like that for several years then you run the risk of UV induced fatigue and a folding black stick, so make sure its been cared for. I suspect that all boats now have the superspar mast. If its an Angel mast be careful that the reinforcements havent blown the composite.
Dont be fooled by people trying to sell a poor boat that has loads of trick take up systems. The original out of the box rope systems all worked perfectly fine and consume less rope.
Sails are pretty long lasting but bolt ropes tear away infront of the batten pockets for a past-time (the joy of a fully battened rig). Its not a big fix and most sail lofts can repair it with a decent kevlar reinforced cloth for a small amount of cash.
Halyard cleats tend to wear. Many boats runs two cleats just to make sure. Some have opted for 2:1 halyards to reduce the load in the cleat, but the original kevlar 1:1 approach is fine as long as you regularly move the knot and cleat point in the rope.
Pro-grip has a tendancy to unpeel with time and a lot of people decided to lavish the cockpit with it. As a result some cockpits look messy where the pro-grip has gone but left evostik residue everywhere. There are also some who chose to cover their boats with sex wax which again makes it look messy. To be honest you only need pro-grip on the wingbars.
Make sure you get a boat with the right wing width. In the good old days it was easy to find swaps but thats less likely now so make sure you get a boat with the right setup. I think its upto 74kg wide wings, 74-80kg either, 80kg+ narrow, but I may be wrong. Best to check the user guide or talk to Anthony York (Chunky) at Northampton as he is the class expert.
OK 2129
RS200 411
Dignhysailor View Drop Down
Post Options Post Options   Quote Dignhysailor Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 16 at 10:57am
Originally posted by rich96
For £3000 you'd get the best RS600 going
Don't discount the 600 - at your size and weight, inland, it would be great
Its the only boat I had that actually made me want just to go sailing regardless of whether there was racing or not
Sure its tricky but it can be awesome too
That's why I thought of the 600 in the first place, the lakes around me aren't the biggest so possibly I'm wrong to even think of a boat with a lot - budget is also a key issue! If I was going to buy a 600 what should I look for (ie wings wise,common faults etc)?
andymck View Drop Down
Post Options Post Options   Quote andymck Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 16 at 9:28am
MPS will go down wind quite happily without kite. Stenhouse rarely puts his up getting to a windy start line. See report from the Tiger. I think the B14 one. This was also the advice he gave me on my third MPS sail when it was blowing old boots at the Rutland open.
There are plenty of idiosyncracies you would need to learn, but you can leave kite for a bit. Though you will want to as it is as quick as is laser slow without.
Andy Mck
