Moth ... no longer 11ft ... |
Page <12 |
| Author | ||
Rupert
Topic: Moth ... no longer 11ft ...Posted: 14 Jun 15 at 6:41pm |
Either 11 feet or about 6 inches? |
17mika
Joined: 03 Nov 06 Location: Italy Online Status: Offline Posts: 53 |
Posted: 17 Jun 15 at 1:09pm |
Well bowsprits and gantrys have to be removable and do not increase buoyancy, so it's definetly hard to consider them as part of the hull lenght. |
2547
Joined: 11 Aug 11 Online Status: Offline Posts: 1151 |
Posted: 17 Jun 15 at 4:55pm |
You wouldn't be able to sail them very well without the bow sprite and gantry though ... so how is that relevant?
Rupert
Posted: 17 Jun 15 at 5:10pm |
You couldn't sail them without mast, sails or foils, either, but I know what you mean, part of a length rule is to test a designer's skills at creating something which works at the given length. Adding sticks at each end means you aren't doing that.
Posted: 17 Jun 15 at 5:25pm |
All box rules are arbitary restrictions though. The Moth rules are framed so that the sticks at each end can't contribute to the hydrodynamics of the hull, which is a pretty reasonable measure of given length. Not that different to say spars overhanging the ends. Funny how the boom overhanging the stern* is something no-one seems bothered about, but the bowsprit overhanging the bow is a bit more serious..
[added later] * speaking generally that is. not specifically about Moths. Edited by JimC - 17 Jun 15 at 8:26pm |
2547
Posted: 17 Jun 15 at 5:33pm |
I think it is all starting to look a bit of a contrivance ...
Although it certainly goes fast and the class is popular so I guess it is all gravy ...
maxibuddah
Posted: 17 Jun 15 at 7:08pm |
What does it matter, none of its in the water.
Rupert
Posted: 17 Jun 15 at 7:10pm |
The only reason I can see for allowing the boom to overhang the transom is to allow it rest on it when the cover is on. Not something that has been an issue for Moths for several decades.
As I've said, I'm torn on all this. With my theory hat on, I think sticking to the 11 feet and having to work round that is very neat. But in reality, the way the Moths actually do it leads to better boats, still closely matched as all are using the same rule set, whatever it is. |
I luv Wight
Joined: 28 Jan 05 Location: United Kingdom Online Status: Offline Posts: 628 |
Posted: 17 Jun 15 at 8:06pm |
The moth rules started pretty simple - 11ft long, 88 sq ft sail, 17 ft luff, and all the
new rules ( with the exception of allowing wands ) are restrictions and not changes to the original ruleset. - ie limited max beam, no windsurfers, no catamarans, limited length for gantries and bowsprits, etc, etc. A true development class - with no rule changes as such in the 30 or 40 years since the class was formed from the various moths around the world ( apart from the wands as mentioned) the PY has halved - from the same as a Solo to 550 ( or even lower at Hayling ). |
Page <12 |
