Adjusting controls |
Page <123> |
Neptune
Joined: 08 Jun 09 Location: Berkshire United Kingdom Online Status: Offline Posts: 1314 |
Topic: Adjusting controlsPosted: 17 Dec 13 at 8:23am |
What is this board adjustment you speak of ;-)
Musto Skiff and Solo sailor
jeffers
Posted: 17 Dec 13 at 8:50am |
Try that in a Laser or anything else with low freeboard and you are almost guaranteed a swim as the boom hits the water. That along with having to overuse the rudder (probably stalling it out) and forcing the boat to bear away simply is not fast.
yellowwelly
Joined: 24 May 13 Online Status: Offline Posts: 2003 |
Posted: 17 Dec 13 at 9:32am |
oh, I remember those days... when foils aligned perfectly, and were neither too big, nor too small and were simply 'just right' for all points of sail, even a muppet could appreciate their beauty.
Rupert
Posted: 17 Dec 13 at 11:05am |
Board adjustment is the thing you remember you haven't done when you go to put it down at the leeward mark, isn't it?
Otherwise, in a boat with a low boom, in a breeze you have to dump some kicker or the bear away will end in tears. |
Neptune
Posted: 17 Dec 13 at 11:19am |
In both my 600 and Musto board adjustment is pretty much put it in when you launch and pull it out when you come in. Not sure either boat actually would go any faster if you adjusted it.
Outhall, used to adjust it a little in my 600, but the Musto never adjust once set up - although with the boom angle pulling on kicker and Cunningham effectively self adjusts it. Cunningham off on any trapeze boat I have owned before windward mark. White sail reach a single handed trap boat unless underpowered leave kicker in the upwind position. |
GybeFunny
Joined: 27 Oct 09 Online Status: Offline Posts: 403 |
Posted: 17 Dec 13 at 11:35am |
In my Laser I concentrate on windward heal to assist a good mark rounding (and keeping the boom out the water) and dont touch anything until I am safely around the mark and have made sure that I am not about to get rolled. I encourage everyone else to fiddle with the controls straight after rounding the mark as it allows me to roll them easier while they have their head in the boat!
patj
Joined: 16 Jul 04 Location: Wiltshire Online Status: Offline Posts: 643 |
Posted: 19 Dec 13 at 6:52am |
Looking at the controls of our latest boat (Albacore) this all sounds like it's easy for singlehanders - as well as kicker, cunningham, outhaul and centreboard, doublehanders have to work out what to do with the shrouds - mast ram - jib tension which are all led back to the helm!
Then we've the wide Merlin to learn which is a whole new vocabulary of pullers, tweakers and snodgers! Edited by patj - 19 Dec 13 at 6:53am |
alstorer
Posted: 19 Dec 13 at 6:56am |
Pfft, not all double handers are complicated. On the B14, if there's enough breeze that we're using the kicker & Cunningham, it's simply dump a load as we go for the bear away- if the kicker's left on, like most boats it'll be hard to bear away, whilst if the cunningham's left on it's a superb way to help snap the mast- then with the fourth hand pull a bit of kicker back on once back out on the wing after hoisting.
Al |
bustinben
Joined: 15 Oct 06 Online Status: Offline Posts: 288 |
Posted: 01 Jan 14 at 10:08am |
Depends on whether you're bearing away onto a reach or a run... if going onto a run and it's breezy I leave the downhaul on a bit to keep the draught forwards in the sail and facilitate the bear away (laser).
Telltale
Joined: 03 May 12 Location: Cardiff Online Status: Offline Posts: 169 |
Posted: 01 Jan 14 at 1:33pm |
OK assuming we all have rounded the mark and the bear away is without incident I've got a question for the control adjustment at the bottom mark, does it make a difference which way round you set the boat up for the beat? I.e. do you set cunningham first or kicker first or doesn't it make the slightest difference?
Page <123> |
