New Posts New Posts RSS Feed: RS 800 Mainsail
RS 800 Mainsail
RS400atC View Drop Down
Post Options Post Options   Quote RS400atC Quote  Post ReplyReply Direct Link To This Post Topic: RS 800 Mainsail
    Posted: 28 Feb 13 at 5:45pm
Can anyone comment on whether a sail of that style will last as long?
My feeling is that the material must be under higher stress supporting that top batten, but I don't know what the real effect is.
I have sailed an 800 a bit, I think the main is pretty old but still works fairly well. On that level, RS800's are cheap to buy and run, and an awful lot of fun. I guess there will be a good supply of used sails now, so a few club-level boats might get newer mains.
I'm not sure it will help the UK circuit, as the difficulty is always getting club sailors to travel. But if RS really can sell a decent number of boats abroad, that has to be good, but I imagine the 49erFX will give them some serious competition?
Cue re-opening the old debate about allowing the crew to pump the main up the beat....
tgruitt View Drop Down
Post Options Post Options   Quote tgruitt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 13 at 5:56pm
It will probably last just as long, they've put an extra batten in so it might last even longer...
Lukepiewalker View Drop Down
Post Options Post Options   Quote Lukepiewalker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 13 at 6:03pm
Freudian slip? LOL
Ex-Finn GBR533 "Pie Hard"
Post Options Post Options   Quote RS400atC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 13 at 6:04pm
Freudian slip? LOL
no.
Post Options Post Options   Quote tgruitt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 13 at 6:12pm
hum3 View Drop Down
Post Options Post Options   Quote hum3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 13 at 6:19pm
The extra batten at the top come at the expense of a full batten a third way down, which means there's quite an ugly crease in the luff of the new sail with no / very little wind in it vs the old one (check it out at the dinghy show this weekend). Whether this proves to be a speed difference remains to be seen, but will only be apparent in <6 knots anyway. As soon as any kicker or cunno comes on, it gets pulled out and the sail sets very nicely.
A full third batten was tested, apparently, but it changed the dynamic of the sail too much (EDIT - in breeze), making it much less manageable, therefore failing the 'should be as usable as the old one' test.
Edited by hum3 - 28 Feb 13 at 6:21pm
carshalton fc View Drop Down
Post Options Post Options   Quote carshalton fc Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 13 at 6:53pm
Looks like a step in the right direction and I can't see it causing any harm to the class. The 14's changed to square top mains a few years ago and they really do make the diffence in the light stuff and being slightly flatter go faster in the heavier winds.
One trick I don't know why they didn't go for is to make the batterns full length for the bottom 3? That is why it has a nasty crease in the middle of the sail.
International 14 1503
Daniel Holman View Drop Down
Post Options Post Options   Quote Daniel Holman Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 13 at 7:01pm
If it had all full length battens it'd become nearly as much of a slut as a 14 Alex.
Soft battens mean that it's less on/off binary in tacks/gybes/manoeuvres at the expense of a little profile stability.
Remember that the remit ( which it fulfills well) is to be accessible to average sailors, mixed crews etc.
An early prototype was shelved because it capsized when left floating while the trolley was grabbed.
14s will capsize if you show it a sniff of heel, and in no wind at all if you don't hold them.
Post Options Post Options   Quote carshalton fc Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 13 at 7:12pm
This is Luke Alex's crew so I fully understand how much of a handful the 14 can be while trying to get on and off the beach. Was just wondering why they didn't go for it.
I am a fan of the 800 and enjoyed sailing it in Minorca with my brother who had never trapezed before or used a kite. It defiantly fills a very good space in the dinghy market for twin wire fun.
Edited by carshalton fc - 28 Feb 13 at 7:16pm
ellistine View Drop Down
Post Options Post Options   Quote ellistine Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 13 at 7:26pm
Pending a successful vote the sails should be available mid May. My wife's birthday is also mid May. Mmm, I wonder.
