RS 200 Battens |
Page <12 |
![]() ![]() ![]() ![]() Posted: 07 Jan 13 at 12:35pm |
Be worth checking your batten tension also. I never had a problem in my 200 (that i can remember) Although had a big problem in the first D-one, it took me months to work out why i was so slow upwind in the light stuff. Turned out that after watching someone else sail the boat the battens were massively too light. Forcing far to much fullness into the sail (which actuallyaltered the cut shape of the sail) I couldnt spot the difference whilst sailing the boat but as above, when someone else was sailing it i noticed it. Once the tension was cracked off my boat speed was then similar to the rest of the fleet. It also meant that the battens snap across with no effort out of the tack.
Maybe just worth double checking.
JVSAIL ![]() Newbie ![]() Joined: 04 Nov 12 Online Status: Offline Posts: 17 |
Cheers guys all different things for me to try out. Kingdacks be careful as you are not allowed to use the gybeing strop for anything else but gybeing (this is a new class rule less than a month old)
Telltale ![]() Posting king ![]() Joined: 03 May 12 Location: Cardiff Online Status: Offline Posts: 169 |
I would be interested in the thinking behind that rule revision, is there a big advantage in using the gybing strop for tacking then? Secondly is the gybing strop an option or is it a standard piece of kit. Does that mean you can't use the falls to crack the main then?
There is almost no advantage in tacking, i believe that it has been put in place because it was being used for pumping. Also as far as i know it is standard but you are allowed to remove it
kingdacks ![]() Posting king ![]() ![]() Joined: 04 Oct 11 Location: Poole Online Status: Offline Posts: 148 |
I thought the class rule, allowed you to still you can use the gybing strop to re straighten out the batterns just not hold the gybing strop down wind to stop pumping. Also you should never remove the gybing strop on the rs200 its essential for gybing in strong wind.
Edited by kingdacks - 07 Jan 13 at 7:19pm |
It has been illegal to use the gybing strop in a 200 for anything but gybing for at least 5 years, probably more.
hum3 ![]() Far too distracted from work ![]() Joined: 23 Jun 06 Online Status: Offline Posts: 247 |
... and the class has just voted overwhelmingly to maintain that rule.
I've never had issues with battens not popping in the 2 when tacking, but have when gybing in the light. Needed a bit MORE batten tension, combined with a bit of kicker during the gybe (released again after)
FYI the 800 does have issues popping the top batten in the light when tacking - only when tacking from port to starboard though, because the batten is sewn in on one side of the main. I often need to give the cunno a pull to get it through when I'm up front, in the pen.
Page <12 |
