New Posts New Posts RSS Feed: Paddle or Oar
Paddle or Oar
kurio99 View Drop Down
Post Options Post Options   Quote kurio99 Quote  Post ReplyReply Direct Link To This Post Topic: Paddle or Oar
    Posted: 16 Aug 10 at 10:07pm
Does anyone else have this problem?  The channel to the boat ramp area is too narrow for tacking and is busy with motor boats.  I have a 50:50 chance of needing to paddle or row into a strong wind, either at the start or the end.
I tried oars which are good for a strong wind but in a small boat, they tend to be underfoot, cramping your floor space and catching your lines.  Paddles take less space, but it is hard to keep the boat straight when single handed and especially in a stiff breeze.  What was your solution (not counting motors)?
What do you do with the rudder?  Remove it, tied it in one position, or let it flop?
What about the boom and sail?  I tried raising the sail and let it swing with the wind, but it kept getting in the way, banging my head.  I tried rowing out with the sail down, but even with some extra distance, I still nearly went on the rocks while raising the sails.
What’s your secret?
FYI, I am using a small boat similar in size to a Mirror.  There is no room on the foredeck for oars without snagging the jib.
Edited by kurio99
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 10 at 10:57pm
Singlehanded or crewed?
Post Options Post Options   Quote kurio99 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 10 at 11:38pm
Singlehanded.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 10 at 8:02am
Not easy...
I think the chances of paddling out against any breeze are low without either one paddler each side or someone operating the tiller to keep the boat straight.
If this is a cruising boat, not a racing boat then I'd fit a topping lift to pull the boom well out of head banging room and row out. I'd probably put the rudder on elastic so it tends to self centre.
For a race boat: well I think I'd find somewhere else to launch!
Garry View Drop Down
Post Options Post Options   Quote Garry Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 10 at 8:51am
In flat water if you can drop the main and release the jib
sheets; remove the rudder and scull backwards with a
paddle. Sounds counter-intuitive I know but once you have
the knack you have both control and power (although its
hard work).
Garry
Garry
Lark 2252, Contender 298
www.cuckoos.eclipse.co.uk
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 10 at 10:14am
timnoyce View Drop Down
Post Options Post Options   Quote timnoyce Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 10 at 12:32pm
...don't forget that those little electric motors need a big heavy battery to power them for any length of time. I looked into it a while back and they were offensively heavy!
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 10 at 12:39pm
Very true.
......and I've just noticed that motors are not an option in the original post.
Edited by GK.LaserII
bferry View Drop Down
Post Options Post Options   Quote bferry Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 10 at 1:16pm
I suggest:
1. fit a roller furling on the jib to be able to reel in quickly and easily,
2. lower the sail to prevent the boom violently swinging from side to side and stow it in the cockpit possibly with some elasticated cord.  You can then tighten mainsheet to centre boom or fit topping lift to raise as suggested by JimC.
3. Raise the rudder and use oars to control direction.
3. fit removable plastic row locks onto the gunwale and make sure its reinforced enough to handle the force of rowing. I've seen this system used on Miracles and Mirrors for cruising.
4. buy a couple of telescopic portable oars similar to the ones in the link below.  They can be stowed in the boat without taking up space. I keep one in my boat for an emergency.
http://www.towerwholesale.co.uk/tower/images/282680pad.jpg
Sculling is a good idea and would give you more power since you are pulling the oars rather than pushing them.  Just keep an eye out behind you every couple of strokes to make sure you avoid obstacles.
Don't agree with electric nor small petrol motors since these take up space on the transom and prevent the rudder from working correctly whilst sailing.  Unless of course you have a boat with an outboard motor bracket fitted purposely. In which case a petrol engine would be better since it would avoid a heavy battery and could incorporate a fuel tank on the motor itself.  I used to use a small Yamaha 2HP 2stroke on the back of my old Miracle.
Google, ‘sailing dinghy cruising’ for more information. There’s a lot out there.  Also try:
http://www.btinternet.com/~sail/cruising.htm
Hope this helps.
Bernard
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 10 at 1:36pm
A simple solution for singlehanded paddling over short distances is the Praddle
http://www.sailboats.co.uk/productinfo.aspx?productID=747530
which you can use with one hand and still hold the tiller in the other. If rowing/paddling further than just off the slipway, then oars as described above will be faster and less tiring.
