Gear Failure |
zailor
Joined: 10 May 09 Location: Penparc Online Status: Offline Posts: 249 |
Topic: Gear FailurePosted: 28 Jun 10 at 6:16pm |
I'm getting quite good at breaking stuff now and just wanted to check I'm not alone.
http://i856.photobucket.com/albums/ab122/MParsons_91/IMGA002 1.jpg |
zailor
Posted: 28 Jun 10 at 7:08pm |
Wee Man
Joined: 24 Aug 06 Location: United Kingdom Online Status: Offline Posts: 214 |
Posted: 28 Jun 10 at 7:17pm |
That was never a F5, don't be so tight, get the Harken bits on and bin the cheap blocks.
Edited by Wee Man |
Merlinboy
Posted: 28 Jun 10 at 7:29pm |
Thats Holt blocks for you!! As poster above said, spend
the extra £1 a block and buy harken! I only have four more blocks to replace then i am free of the cack! |
Smight at BBSC
Joined: 09 Jan 07 Location: Great Britain Online Status: Offline Posts: 1129 |
Posted: 28 Jun 10 at 7:48pm |
Gotta say despite being very biased the only block that ever break on the 14 are the holt ones we havn't replaced yet...The evidence is pretty plain.
RS600 988
zailor
Posted: 28 Jun 10 at 8:57pm |
Was when I gybed Anyone else got pics of exploding kit? Edited by zailor |
tmoore
Joined: 01 Nov 07 Location: Wales Online Status: Offline Posts: 880 |
Posted: 28 Jun 10 at 9:27pm |
I did a similar thing to my laser kicker a few year back except it was a 'hi-tension' one meant to be extra strong. Looking at your 'spares' you have a harken 16mm air block, that should be man enough. Its not worth switching everything over but when things break just spend the extra pennies. That said, when my kicker is cranked right on the 10+ year old holts were absolutely fine under big loads. Replaced with harken from the spares box when I re-spliced a new line in though just to make sure. |
Landlocked in Africa
zailor
Posted: 28 Jun 10 at 9:42pm |
I've made an all harken set up now so if that blows up heads will fly! |
RodB
Joined: 01 Sep 05 Location: United Kingdom Online Status: Offline Posts: 75 |
Posted: 28 Jun 10 at 9:46pm |
I don't know why you're so proud of this disaster? F5 big deal !
what did you expect with those toy bb blocks. I'd maybe use them for tidying control lines. My philosophy is to always go much higher spec than you need. If the blocks are overspec'd, they'll never break. Only the dyneema, if worn around the attachment points, will give. Other than that it's the fixings - in which case, bolt them rather than screw them in. Time to man up and get your boat sorted
R |
laser193713
Joined: 13 May 09 Location: United Kingdom Online Status: Offline Posts: 889 |
Posted: 28 Jun 10 at 10:09pm |
I have to say that Rods boat is probably the most sturdy feeling boat i have sailed in a long time! Took it out in plymouth with him a while back looking at sails and you really could just look at the sails without wondering whether the kicker would blow up in your face in a gybe! I do like the B14 too. There is something incredibly smooth about the way it sails! Also with Rod you know that if something does break then there are plenty of spares available too! |
