Towing - knots |
Nudge ![]() Newbie ![]() Joined: 08 Aug 06 Online Status: Offline Posts: 10 |
![]() ![]() ![]() ![]() Posted: 08 Apr 08 at 9:35pm |
Sounds a simple question, but I’m stumped. What’s the best knot to use when tying the bow of a dinghy to the trolley/trailer when towing? I’ve tried a few knots and how ever tight I make them after a bit of wiggling the rope becomes a little slack. This slack I presume will allow my nice dinghy to bounce up and down from the many potholes we have on our roads which I guess will equate to a broken dinghy over time. |
DaveL ![]() Posting king ![]() ![]() Joined: 28 Oct 07 Location: United Kingdom Online Status: Offline Posts: 111 |
when tying the boat to the trailer i use halfhitches, when the trolley is attached to the trailer i create a purchase system out of rope then pull tight and tie off with about 4 half hitches, nice and simple. i sometimes use ratchet straps but always remember to put pads under the sides otherwise you could cause damage
Contender GBR443
National 12 - 2859 "Dogmatic" |
May sound like a daft question but what boat are you towing?
I tow a Laser and an RS200 (separatly). I tie both down with two straps, one ratchet strap over the middle of the boat, the second towards the front to keep the bow down. The Laser doesnt move cos I tie it down to the trailer and the road base separatly. The RS I tie to the trolley using the normal method, but also the bow down to the trailer. The issue I found with that was the boat does slide back, because of the angle from boat to trolley, but just checked after a while and tighten if necessary. (Hope this makes sense, but basically tie down halfway from the bow to the centre tie down!!) |
lorrie drivers hitch
TWO FRANK-Hunter Impala
Splosh ![]() Far too distracted from work ![]() ![]() Joined: 13 May 07 Location: United Kingdom Online Status: Offline Posts: 497 |
And always remember... ...If you cant tie knots tie LOTS! |
RS300 - 346 :D
Yes the lorry drivers hitch - also called the wagoners hitch is a simple and convenient way of producing a multipurchase from a piece of rope. I use it in all sorts of situations. The only knot I use more often is the bowline which as most people know you can always undo no matter what load you've put on it.
Ratchet straps for holding the boat down i have a small one what goes through the jib shackle on the bow and then down round the trailor (i find if the strap on the bow isnt through a fixed point it slides forwards and becomes loose), Then have a nice big ratchet strap (3 tonne braking strain, bit excessive on a 50kg boat but its nice and wide so spreads the load on the gunwhales) over the middle of the boat. Mast is held on with a couple of tiger ties.
And check everything again after you have gone about a mile.
MerlinMags ![]() Admin Group ![]() ![]() Joined: 19 Mar 04 Location: UK, Guildford Online Status: Offline Posts: 588 |
How to tie it!
http://www.animatedknots.com/truckers/ |
