Sail repairs |
friendly_fire ![]() Groupie ![]() ![]() Joined: 25 Nov 07 Online Status: Offline Posts: 70 |
![]() ![]() ![]() ![]() Posted: 10 Dec 07 at 10:01am |
you can use diffrent tapes they are good on diffrent materials. my parents make spinnikers and we use captin tape from bainbridge. this is good for non silicon coated materials like the airex range. however if the material has a silcon coating something like basting tape would be better
when chuck norris does a press up, he doesnt lift himself up he pushes the earth down
Fin. ![]() Posting king ![]() Joined: 12 Feb 07 Location: Ireland Online Status: Offline Posts: 128 |
Silicone ...what kind ....stuff you use for the bathv (from BnQ), or, stuff for sealing hatches on a boat ? or is there other silicone to be reccommended (brand for example) ?. (might give the iron a go (while the missus is out (she might get ideas!) /fin |
....So that's where I'm going wrong
It is kind of self explanatory! you'll know if you pick it up by the wrong side! Neil 29er GBR394 |
I got fed up with the Tape falling off so I stitched them on. Untwisted and seperated the threads of whipping twin to give me a fine thread and cross stiched them on. Round corners on the patches. Although I might give the silicone sealant a go next time.......I don't know how to use an iron though
The trick with spinny tape is to iron it on - not too hot though - just so that you can touch the bottom of the iron without burning yourself - so that the glue from the tape goes into the weave of the cloth. If you do it right it will *never* come off - which might be a problem if you want to get it repaired properly!
Spinnaker repair tape often doesn't stick because the sail is coated with silicone. A neat tip that I picked up from Lester Noble that apparently came from the 49er fleet is to use silicone sealant! It works - honest. It's unnafected by the silicone coating. I've used it several times now and it's been 100% successful. Also passed the tip on to several others who now swear by this method. Use the clear version, and smear it as thinly as possible onto the sticky side of spinnaker repair tape (fingers work best). Make sure you have 100% coverage, then place over the hole / tear etc. It takes about an hour to dry, but once set sticks like s**t to a blanket. It's also very flexible and so hardly affects the shape at all. Word of warning - don't get any on furniture, carpets, cloths etc - your mum won't like that! Edited by Hector |
dave21 ![]() Newbie ![]() Joined: 12 Nov 07 Location: United Kingdom Online Status: Offline Posts: 8 |
Thanks for the replys... sailcloth.co.uk - what a site - now all I have to do is figure which material is which! Thanks again, |
DaveT ![]() Groupie ![]() Joined: 31 May 05 Location: United Kingdom Online Status: Offline Posts: 76 |
Basting tape, its like a v sticky double sided tape, try www.sailcloth.co.uk or ask your local loft if they might sell you some.
tapes called captain tape or something like that
