420 deck to hulll!! |
scottishgem
Joined: 10 Sep 05 Location: United Kingdom Online Status: Offline Posts: 16 |
Topic: 420 deck to hulll!!Posted: 07 Feb 07 at 2:32pm |
Hi all i need to repair the seam between the hull and deck on our 420, shes letting in a fair bit of water esp, when upside down!! i thought fibreglass tape would be the best option but a bit bewildered about where to buy..? not as keen on matting from our local diy store as it looks poo, also, what is the best covering paint/gelcoat? gem x |
jeffers
Posted: 08 Feb 07 at 8:17am |
Hi Gem,
I dont think glass matting et al would be the way to go here. If memory serves the 420 deck/hull joint rolls over and the 2 halves are glued together. You may find you stand a better chance by digging the old glue out and replacing it with new (I used wests when i did my Laser). Not only will it look neater it will probably be stronger as well. Paul |
Blobby
Joined: 07 May 04 Location: Australia Online Status: Offline Posts: 779 |
Posted: 08 Feb 07 at 12:28pm |
The Hobie Tiger trick to solve leaky dagger board cases is to thin out some polyester resin and then pour it inside the hull and rotate the hull to get the resin to the leaky joint - just leave the inspection hatch open long enough to vent the thinner and don't put a match inside it to see if it has gone off... |
Rupert
Posted: 08 Feb 07 at 7:53pm |
Mending the 420 is more like mending a Laser. You have to turn the boat over, dig out all the glop round where the joint has failed, as Jeffers says. I know most professional repairs say to use the same material to mend the boat as was used to build it, in this case thickened polyester resin. I've both used epoxy and polyester on these jobs in the past, and found both work. Most important thing is to get rid of what was in there first, even drilling down into it or using a router, if you dare!
olly_love
Joined: 18 Jan 05 Location: United Kingdom Online Status: Offline Posts: 1145 |
Posted: 08 Feb 07 at 8:12pm |
a nice bog of epoxy and microfibers will be very strong and then possiably wrap some glass tape over it all. you can get all of this stuff online from shops like purple marine ldc northampton sailboats |
TWO FRANK-Hunter Impala
Rupert
Posted: 09 Feb 07 at 8:55am |
If you do the scraping out and the "bog" properly, there will be no need for the glass tape, so leaving the gunwale looking as it did before.
Lucy Lee
Joined: 17 Mar 04 Location: United Kingdom Online Status: Offline Posts: 276 |
Posted: 09 Feb 07 at 9:54pm |
Post a picture of the problem area & we'll have a better idea what to advise..
Fly Cherub!
scottishgem
Posted: 10 Feb 07 at 3:20pm |
Cool thanks all!! I will try to get some photos to post asap, its under gaffa tape just now and we're taking it away to a race now for tomorrow. (good old gaffa tape!!) but as its half term and im a teacher ive got loads of time to tinker with it this week |
jeffers
Posted: 12 Feb 07 at 9:23am |
Spare a thought for us support staff who are still slaving away while you have your week of leisure....... |
scottishgem
Posted: 12 Feb 07 at 11:42am |
eh? all our LSA's and NNEB's are off too, what sort of support work do you do? Greatest sympathy
gem |
