Argo vs Lazer 2000 |
Page 123> |
![]() ![]() ![]() ![]() Posted: 18 Aug 21 at 4:31pm |
Au contraire Gordon, I'm quite OK with them, just don't recommend them to folk who ask.. And here's a little message from me to you whilst sailing one.. ![]() ![]() ![]() Edited by iGRF - 18 Aug 21 at 4:32pm |
I note the people who consider the RS200 "really quite docile" are experienced sailors with N12, RS300 and Musrto Skiff in their recent history, all of which are generally accepted as 'difficult to sail"...
Gordon 1430 ![]() Far too distracted from work ![]() Joined: 27 Jun 17 Location: Lee on Solent Online Status: Offline Posts: 310 |
very different. 2000 heavy solid underpowered good boat for novice and bandit in a blow.
RS200 Much lighter has massive following hence 120 boat nationals great team work boat. unsuitable for kent dinosaurs
Phantom 1430 |
Are the 2000 and RS200 the same boat?
Surprised at the amount Enterprise race returns have dropped. |
Robert
A product from another time, when folk were conned into believing it's because they were bad sailors that a particular craft didn't work as it should. Happily that time has now past, thanks in part to the advent of people discussing things like this on the internet and refusing to be 'shamed' into believing they were not 'good enough' unless they spent every hour of every day practising, because this or that outrageously difficult craft needed very skilled handling. Fact is, sailing in the elements, learning the vaguaries of the wind, shifts, tides, currents, interboat tactics, is difficult and enjoyable enough (if you get it right) without some badly designed, in some cases over canvassed, un stable nightmare adding to the problem and removing the joy of sailing in strong wind. One day I think I'm going to compile a list of boats to avoid and you can trust me when I say the 200 will be right up there, my real problem however is finding any not to put on the list, every single one of them has its problems and you do need to put some effort in, to master any boats foibles. But some are more worth the effort than others. I wouldn't waste another hour on an RS200 unless you're set on class racing and have a very good crew. Edited by iGRF - 18 Aug 21 at 1:30pm |
According to the PY data the RS200 is the most popular two handed class in the country, so they must be doing something right.
It is a fairly lively boat, which AIUI is why it gained the skeg during development to make it a bit less twitchy, but its clearly not in the same league of difficulty as high performance boats. |
Sussex Lad ![]() Far too distracted from work ![]() Joined: 08 Jun 18 Online Status: Offline Posts: 360 |
N12......all that work for so little forward progress.
![]() Thought the 200 was based on a 12. Designed by 12 sailor and previous 12 designer. They have much in common. ......anyway, it's a horses for courses thing. |
Gfinch ![]() Groupie ![]() ![]() Joined: 09 Nov 09 Location: United Kingdom Online Status: Offline Posts: 67 |
Yes, but when I last sailed one it was a directly after some N12 sailing....
3513, 3551 - National 12
136069 - Laser 32541 - Mirror 4501 - Laser 4000 |
eric_c ![]() Far too distracted from work ![]() Joined: 21 Jan 18 Online Status: Offline Posts: 382 |
Trim problems in a short boat with the heavier person at the back and the cockpit divided by a centre mainsheet.... Hardly specific to the 200 I think! If anything, is the 200 too docile? A few rides in a 400 which gives more feedback might be good for learning? Or with the light crew, maybe consider one of the trap asy boats which are a little faster than the 200? Experiencing different boats is good, if you can do it without buying lots of boats better still!
Like all boats a lot tends to be based upon your references, having sailed and got over the learning hump on some tricky boats I’d say the 200 is actually really quite docile and it’s sensitivity is really more down to longitudinal trim. As someone who’s possibly a little heavier than you that’s the problem I’ve found with mine is keeping weight forward especially if you are not hiking.
It’s summer, waters warm, stick with it and if things go wrong provided the crew doesn’t worry it’s not clear where the problem is.
Musto Skiff and Solo sailor
Page 123> |
