Control lines |
snowleopard ![]() Groupie ![]() ![]() Joined: 02 Oct 17 Location: Cornwall Online Status: Offline Posts: 66 |
![]() ![]() ![]() ![]() Posted: 30 Oct 17 at 8:48pm |
In the process of assembling my new (to me) Finn, I am at a loss:
There are the usual suspects - kicker, outhaul, cunningham, plate up and down plus loads of other obscure but understandable bits like toe strap tensioners and transom flap closers but there is also one I have never come across before: a tack tensioner. Why would one use that in addition to foot outhaul and cunningham?
Edited by snowleopard - 30 Oct 17 at 8:49pm |
Ask the Solos
Inhaul flattens the lower entry of the mainsail; also efficient way of putting fullness into the main without having to let the outhaul off. In the Solo you simply let the inhaul off at the windward mark and pull it on to a preset at the leeward ... well that’s what I do. I suspect that Finnfare has plenty on this.
Happily living in the past
Have you tried the Finn UK Class Assoc? They are a friendly bunch of guys in my experience. If you are on Facebook they have a good page there.
I have also recently bought a Finn, and took it to a cvrda meeting with some other h lpful Finn sailors who say the kicker and the inhaul are the most important controls in the boat, and the Dow haul the least important. Pull the inhaul on upwind but have the kicker off - use the mainsheet and the traveller to control power, keeping the sheet right most of the time. Offline put the kicker on to create power, release the inhaul to put shape back into the sail.
There is useful information on the BFA website, including information about mast rake which is also important, but you have to match it to mast and sail.
KazRob ![]() Far too distracted from work ![]() ![]() Joined: 22 Oct 16 Location: Scotland Online Status: Offline Posts: 245 |
The inhaul can just be the coolest control there is. If you ease it, it flattens the entry low down on the main, which can make it quicker but gives a very narrow groove to steer in. Pulling it on does the opposite being a bit more draggy but with a much wider and easier to sail groove to sail in. It also helps open (pull it on) and close (ease it off) the lower leech which can help you point or foot (remember on a Finn the boom is sheeted down so a 'closed' leech as you look at it can still be open relative to the boat centreline). If you have a sail with two telltales with one around a foot or so behind the mast and a few feet up from the boom and the other a foot or so directly behind the first you can use those to help fine tune the sail entry by adjusting the inhaul. Have fun
OK 2249
D-1 138 |
Some interesting food for thought there. All the boats I have sailed for the last 30 years have had loose-footed mains and fixed tacks so it will be a new experience. Investing in a shed load of telltales sounds like a good starting point.
Does tack inhaul make no difference to loose footed mainsails then?
I've no idea about loose footed mains as never had an inhaul on one but no reason why moving the tack wouldn't work if sail was cut for it
OK 2249
D-1 138 |
I guess it must change the shape of the bottom of the sail whether it has been cut with that in mind or not. Will experiment on the Blaze, the normal systems just attache the tack to the mast with either a rope or bungee and no specific length is recommended. I have a dynema strop which keeps the tack roughly in line with the luff but wouldn't any more than a little cunningham tension make an adjustable tack inhaul redundant?
