Knots |
about a boat
Topic: KnotsPosted: 16 May 16 at 2:47pm |
So what is the best knot to tie a bit of rope to a bungee cord?
zippyRN
Joined: 14 Sep 06 Online Status: Offline Posts: 437 |
Posted: 16 May 16 at 2:52pm |
sheet bend (doubled if necessary) is the traditional recommendation for joining dissimilar ropes ( reef knot being more suited to similar ropes)
Posted: 16 May 16 at 3:33pm |
It depends, but I'd most likely use a fisherman's knot, but if it were going to be permanent consider a seized or sewn loop in the shock cord and an eye splice in the rope.
realnutter
Joined: 17 Nov 15 Location: Reading, UK Online Status: Offline Posts: 129 |
Posted: 16 May 16 at 6:15pm |
A sewn loop in the shock cord, with a piece of heatshrink tubing over it to keep it tidy:
Rupert
Posted: 16 May 16 at 6:51pm |
If temporary, agree with double sheetbend.
transient
Posted: 17 May 16 at 7:23am |
When sailing in potential shallows I put a doubled up length of shockcord in my rudder downhaul. The double sheetbend has always done the job well.
about a boat
Posted: 17 May 16 at 1:15pm |
Thanks. It will be permanent as it will be inside the mast. Tried sewing a loop last night. God was it hard to get the needle through! Gave up. The double sheet bend holds up well as the bungee contracts on the other line when pulled tight.
Presuming Ed
Joined: 26 Feb 05 Location: United Kingdom Online Status: Offline Posts: 641 |
Posted: 17 May 16 at 1:23pm |
Chinese finger trap the shock cord inside the cover, secure with a couple of sewn whippings?
iGRF
Posted: 18 May 16 at 12:24pm |
I'd like to know the answer to this one, my Granny doesn't seem to cut it..
Brass
Posted: 18 May 16 at 1:21pm |
More half hitches. If you can't do knots do lots. Plastic tape over the top of everything.
