NoR v SIs |
Page 123> |
![]() ![]() ![]() ![]() Posted: 04 Dec 14 at 6:02pm |
1) If there is a discrepancy between the notice of race and sailing instructions, which takes precedence?
2) Is it acceptable to state in the NoR that, in the event of a discrepancy, the NoR takes precedence?
JimC ![]() Really should get out more ![]() ![]() Joined: 17 May 04 Location: United Kingdom Online Status: Online Posts: 6661 |
I don't see it would be possible to provide a hard and fast rule for which one has precedence. After all in general they should have different things in, and we are dealing with documents that are intrinsically badly written, so if the SI version is permissable and the NOR version not permissable it would be damn silly to say nevertheless the NOR takes precedence. Best to just get 'em right in the first place of course. |
Unless you are a really experienced and careful drafter and intend documents to have a precedence, precedence of documents clauses are always a bad idea.
Rule 63.7 provides a much better way of fixing mistakes. If you intend to change something between the NOR and the SI, then issue an amendment to the document you want overridden.
SIs often include a clause stating that in case of conflict the SIs take precedence. This usually means that either the person writing the SIs was not consulted about the NOR or has not read them (a cynical point of view, almost as cynical as JimC's evaluation of race documents)!
Unless this SI includes the words 'This changes rule 63.7' then it has no value and the PC should ignore the SI and apply rule 63.7. |
Oi!
I wasn't saying all race documents are badly written, only those in which there is a conflict... |
MikeBz ![]() Really should get out more ![]() ![]() Joined: 21 Apr 04 Location: United Kingdom Online Status: Offline Posts: 536 |
I suspect that the clause in SIs about precedence is because in practice they tend to be issued later. Get the NOR out good and early so people know when the event is and then write/refine the SIs over a period of time. Not saying this is necessarily best practice but it's often what actually happens.
Keep the NoR simple - what does it actually need? What the event is, where it is, when it is, what time it starts, how much it costs. Anything else needed, as opposed to wanted?
It's absolutely best practice to get the NOR out early and follow up with SI later (at the time you say you will issue them in the NOR). It remains poor practice to insert a precedence of documents clause, and may, as Gordon has said, be invalid. The way to avoid problems of inconsistency is for the organising committee of the Organising Authority to:
The Race Committee should:
Note, issue drafting instructions and review drafts in committee but do NOT try to draft complex instructions in committee. It's a one person job.
By all means keep the NOR simple, but you must comply with the contents required by rule J1.1 and should comply with the requirements of rule J1.2.
I'm not sure Rule 63.7 would have helped in a race I sailed in last year.
The NOR and SIs both included the course, but the passing direction of the last mark, which lay effectively in the middle of the proper course, was changed from port in the NOR to starboard in the SIs (the committee was concerned about where to place the committee boat if they decided to shorten). There was no warning of the change or statement of precedence in the SIs. Given that the NOR was available weeks before the event, and the SIs only on the morning of the event, it would have been reasonable to put the course on the boat in advance to save time while rushing about before the race. In the event there were no protests and it's possible everyone passed the same side (it was a long race and the fleet widely spread), but it seems to me that any protest regarding someone who passed according to the NOR would have been tricky to decide. Any suggestions as to the outcome?
MM, were you expecting replies to your post?
FWIW, had there been a protest or request for redress, I think, subject to what other judges might argue for, that the course prescribed in the SI was the course required, if only because the SI are the document issued later in time.
Page 123> |
