Lateen Sails |
pedroj ![]() Newbie ![]() Joined: 16 Oct 14 Location: Brazil Online Status: Offline Posts: 5 |
![]() ![]() ![]() ![]() Posted: 16 Oct 14 at 11:21pm |
I didn´t know about those arab dhows. What a beautyfull boat. Thanks for the direction!!
wonderfull. tks pedro |
Thanks Transient,
What I did today is not to drop the yard and the sail. We make one yard line from the boom looser and pull it vertical with another control line. Once it is vertical the wind by tacking pushes it to the other side of the mast. Than I set the yard line free and so it goes back to the front (but allready on the other side of the mast). A second line brings it back to the right position in the boom. Wow, it sounds complicated when I try to describe it. Sorry. |
Yes, it works. I did it today on my laser/lateen sail experiment.
I cuted a piece of the yard in the boom side and now I can quickly put the yard on port or starboard. I pull the yard to a vertical position, change the side of the mast and the it loose again. The yard is connected to the mast but the boom is free. Tacking is already much faster. The connection of the yard to the mast is now 15cm higher too. Doing this I noticed that the boat sails faster upwind in the vertical yard position. Not while reaching. Yes, I needed two control lines to swing the yard from one side to the other. sorry if it sounds like I am inventing the wheel and boiling water. I read carefully your opinions and ideas and try to make this better. thanks, Pedro |
What you hace there looks to be closer to what the Arab Dhows use - could be worth having a look in that direction.
I think I follow you. If I've got this right your idea will only work on an unstayed rig, shrouds would get in the way.
Another rig that suffered from a miss shaped main on one tack was the lugger. This problem was addressed in the "Dipping Lugsail". The yard and sail were dropped, the tack disconnected and the whole shooting match re-rigged on the other side and raised again......it took about 10 minutes to tack. Not terrible popular with the crew I wouldn't have thought. http://en.wikipedia.org/wiki/Lugger |
Thank you Rupert,
The thing I notice with this kind of rig is the confort on board. The sail is smooth and there's no danger for the head. When I have a lot of goods (flowers) in the boat, I can tack in a very easy way since there is no boom. And the part of the sail in front of the mast, somehow reduces the strenght needed for the main sheet. It is a beautyfull confortable sailing. The rigging in and out takes one minute. Pedro
Hi everyone,
I am also working on a small lateen sail sailboat solution for farm goods transportation to the city. Please look at the pictures in http://www.boatdesign.net/forums/sailboats/saveiro-sail-boat-51648.html#post708626 and on the youtube at https://www.youtube.com/watch?v=9-Smzst8hPA with I tried to swing the sail over the mast and normally there is no problem. If it stucks on the top of the mast, simply fast pull the main sh*t loosens it (yellow in the video). But the best is to shorten the distance from the top of the sail till the top of the mast. From what I saw in other sail boats, a good solution is to use a line in the front part of the sail connected to the bow and make the sail so that you can turn it vertically behind the mast. Then you attache the line again to the bow. This means you need someone with you in the boat. Since I sail alone a prefer to have the longer version of the sail. Please look at the video. You might wonder why this sail and not to buy a perfect one in the shop. Well, there is no shop here and second reason is that I did it all for maybe 30-40 euros. Does anybody know how to make my lateen sail faster? Thank you, Pedro |
You can put a bipod mast up, so the sail pulls up in a triangle, rather than on one side of the mast, but the engineering problems and added weight might not be worth the trouble. I was sailing a lateen rigged boat yesterday, and the upwind performance was poor on both tacks, the mast making little difference. Offwind, the boat was a lot more fun, and a lateen rig can't be ruled out as a sail plan just because it isn't popular currently (or ever) in the UK.
However, there are more efficient rigs out there, even excluding the bermudan. As MM says, the crab claw works better, and on some points of sail is very efficient indeed. Another book to look at is Small Boat Sails, by Jeremy Howard Williams - much less technical than Marchaj, and so more accessible for numpties like me. |
Shoepuppy ![]() Newbie ![]() Joined: 22 Sep 14 Location: Eugene, Oregon Online Status: Offline Posts: 2 |
Hi, and thanks for the response. It seems that for a lubber looking for wind power, simple really might be better. Did see a picture a few minutes ago that showed a mast on both sides of the boat with one of those lateen like sails with a yard like thing on the top and on the bottom. It looked really cool, and maybe even slightly easy. Thanks, and happy happies. Shoepuppy
That looks like it might work, but I know very little about lateen rigs except that they are not very efficient - you'd be better off choosing a crab's claw sail in some cases, for example.
You might like to take a look at Marchaj's "Sail Performance: Techniques to Maximise Sail Power" where he looks at them briefly in he context of other alternatives. Edit: the dipping lug rig addresses a similar issue to you http://www.diy-wood-boat.com/dipping-lug.html Edited by Medway Maniac - 27 Sep 14 at 9:53am |
