Garmin GPS 72H |
![]() ![]() ![]() ![]() Posted: 14 Jul 14 at 4:42pm |
Could anyone recommend where I could find a detailed set of instructions on how to use the above GPS please. The manual that comes with it is useless. I want to use it for laying marks.
https://support.garmin.com/support/manuals/searchManuals.faces
See, that wasn't so hard to Google was it?
My original post was prompted by the lack of detail in the Garmnin getting started manual and the owners manual both of which which I downloaded when I got the GPS. I was hoping that someone might know for have a really detaied manual or book. I have also looked through numerous YouTube videos but I was unable to find what I wanted.
Sounds like the usual story with Garmin GPS. I have usually found a website where someone describes the functions and tricks, at least for the cycling products, but the manuals are hopeless. Otherwise, it is just the use of trial and error and intelligence, I'm afraid, unless you're lucky enough to meet someone with the same unit. |
We did a mark laying course using these not very long ago, I got a handout with it which could be scanned and forwarded. Pm me your email address?
I'm not sure that it's the keystroke sequences you need. Mark laying with a GPS doesn't need any very sophisticated use of the GPS. You can get by with just Pinging a position, setting GO TO and display of bearing and distance to a waypoint. Using Project Location is a bonus.
You can't expect the Garmin manuals to tell you how to use a GPS to lay marks, that's what your RYA RO or mark layers course will do. The ISAF Race Management Manual (RMM) contains all you really need to know. Marks can be laid by GPS using the following methods
I prefer the common Reference Point method because it's simplest (very simple for 60 degree triangles and 70 degree trapezoids). For what it's worth, here's what I do (a real RO or IML may come along and put me right).
Edited by Brass - 16 Jul 14 at 6:14am |
Brass - thanks for your detailed reply and the link. I have a fair idea what I want to do but lack the detail on how to do it. I am going to see if I can find somone with the same GPS as me to compare notes.
Actually, it is the correct key stroke sequence that you need, because the 72h is not that intuitive, and if you wZnt yo get the marks laid or moved quickly, knowing the sequence of buttons to press is really helpful. That's why we were given the handout.
I'll get it copied and sent.
Haven't seen the step by steps from Winging It yet.
The procedure I described requires only four GPS functions:
Additionally, using Project Location to move a Waypoint to a specified bearing and distance from a known position is useful. I think all these functions are pretty readily discovered from the user manual, but if you tell us which ones you can't do, then we can perhaps help you out. |
Ok, finally found my notes. They are for the Garmin 76, the 72H is basically the updated version and is the unit we actually used. The notes, from a powerpoint, go through how to set waypoints, clear them and go to them, which is basically all you need. we then went out and used the reference system, where a boat provides a reference point and you proceed according to which marks you are laying.
I think it's all pretty straightforward, it's just remembering the essential keystrokes under pressure. Edited by winging it - 21 Jul 14 at 11:07am |
