200 kicker position |
Page 123> |
piglet
Joined: 04 Jan 07 Online Status: Offline Posts: 514 |
Topic: 200 kicker positionPosted: 05 Jun 14 at 4:56pm |
We seem to be struggling to get the 200 main flat enough, despite pulling the spreaders way back.
Someone no older but much wiser told me to check the position of the kicker bracket on the boom as a previous owner may have moved it forward for the crews comfort.
So, our distance from centre of kicker fitting to front of booms aluminium extrusion = 386mm.
Said wise mans measures from centre of kicker fitting to back of mast track =535mm
Obviously a difference in measuring methods but I will measure to the mast this weekend.
Can anyone beat this? Is anyone out there sad enough to have measured this on a 200?
transient
Posted: 05 Jun 14 at 5:12pm |
Yer in luck Mr piglet....I 'appen to 'ave a 200 in my garage at this very mo.
385mm from the centre of the fitting to the end of extrusion. Edited by transient - 05 Jun 14 at 5:12pm |
piglet
Posted: 05 Jun 14 at 5:49pm |
Thanks Transient, same as mine then.
Maybe I should try it further back anyhow?
transient
Posted: 05 Jun 14 at 6:00pm |
......said the Bishop to the actress.
Posted: 05 Jun 14 at 6:04pm |
Looking at the RS 200 rules I can't see you're permitted to change the position of the thing.
transient
Posted: 05 Jun 14 at 6:06pm |
and as the actress replied to the Bishop "you be careful you don't bend something".
Steve411
Joined: 09 Sep 08 Location: Cheddar, Somerset, England Online Status: Offline Posts: 705 |
Posted: 05 Jun 14 at 6:16pm |
If it's a cascade system, the length of each of the throws will be important. I would imagine that all the blocks should be hard up against each other when the kicker is fully off, otherwise there won't be enough travel in the cascade as a whole.
Edited by Steve411 - 05 Jun 14 at 6:17pm |
jaydub
Joined: 06 Jan 07 Online Status: Offline Posts: 267 |
Posted: 05 Jun 14 at 6:48pm |
First of all, what vintage is your 2. There was a change in I think about 2008 from 8:1 kickers to 16:1 kickers. It's well worth changing if you are still on 8:1, not so much because you can't get the required tension on without he additional purchase, it just makes it much less painful on your hands!
The cunningham is key if you are totally overpowered and flogging the main. It opens the leach and helps lose power from the main.
Flatten off the outhaul as well, although this is less critical as it only really affects the sail shape up to about the second batten.
Make sure your spreader settings are in line with the settings posted on the Class Association web site. They might not be recent, but they are still valid. If you go too far from them, you might gain in some conditions but you will lose out more in others.
Sailing upwind when you are overpowered is a balance between stuffing it and keeping the power on. It just takes some practice to find the groove!
Hope this helps.
piglet
Posted: 06 Jun 14 at 2:27pm |
JimC, I have sought clarification on the legallity of this, will report back.
Jaydub, this is a 2005 and has 16:1 cascade, which I have replaced with all Dyneema & BB stock. There is plenty of scope at both limits of travel.
What stops it going any more is my lack of physical strength and my reluctance to rip the cleats off the thwart.
I tried 8:1 cascade on the downhaul but couldn't get it to work round all the clutter & TackTick bracket so reverted to 4:1. I havent yet seen anyone using a true 8:1 ,though I'm sure some are.
Again what stops the downhaul is that it just won't go anymore.
Outhaul goes bar tight except in waves.
Spreaders were standard setup (135 deflection?) and are now 160. Can't remember the length.
On a recent traing session video it was clear that our mast was too straight and luff too full compared with another 200.
jaydub
Posted: 06 Jun 14 at 3:13pm |
I'm struggling to explain why your mast should be too straight from what you are saying. With a 16:1 kicker, I tend not to fully pull it on when it's aboslutely honking. It's easier to keep the boat on it's feet if you give the air more opportunity to escape out of the leech. I pull it on harder when it's not survival conditiions, but never to the extent that my hand hurts.
Spreader settings are dependent on all up crew weight, but we sail off fairly standard settings - 395mm length; 135 deflection @ 21.5 stone. I used the same settings on our previous late 2004 vintage boat. I've never heard of anybody using anything like as much as 160, so would suggest yiou revert back.
What's your mast rake set at? 21' 8.5" with one hole showing at the mast foot is pretty standard. Worth trying more rake if you are really struggling.
I'll try and remember to measure my boom take off measurement for you on Sunday. I don't believe there is anything in the rules to stop you sliding it further back, but it will encroach on crew space and encourage more mast bend in intermediate conditions, which may not be a good thing.
Page 123> |
