New Posts New Posts RSS Feed: Mast head lock
Mast head lock
batman View Drop Down
Post Options Post Options   Quote batman Quote  Post ReplyReply Direct Link To This Post Topic: Mast head lock
    Posted: 14 Jan 13 at 3:06pm
Main halyard lock at the mast head. The main benefit I believe is that they take the compression out of the mast. I'm not an engineer- what practical benefits will I feel on a Fireball? Some sailors are swapping to them and I know 470s use them- but at a cost of around £80 and some fitting work is it worth it?
The jib halyard has a 2:1 at the top so the load on that is halved- but isnt this putting the rig under far compression that a main halyard would?
SoggyBadger View Drop Down
Post Options Post Options   Quote SoggyBadger Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 13 at 4:01pm
It's not just compression. In the normal situation where the halyard is made fast at the base of the mast somewhere when the mast bends the distance head to heel reduces so the halyard slackens and the main comes down a bit.
Edited by SoggyBadger - 14 Jan 13 at 4:02pm
SB
maxibuddah View Drop Down
Post Options Post Options   Quote maxibuddah Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 13 at 4:33pm
No or very low stretch in the halyard as well.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 13 at 5:21pm
Which is why certain classes don't use jib halyards.
The compression puts extra bend in a mast. Provided that the mast stiffness is correct with the halyard loads this is not that much of an issue, but you should be able to use a lighter or more flexible section without halyard compression. I have an excessively bendy topmast on my IC for my current waistline, and putting a main halyard lock on made a very substantial difference to keeping the rig powered up.
If your rig is over bending then a halyard lock may help. If its already on the stiff side then a halyard lock will probaby make things worse!
Edited by JimC - 14 Jan 13 at 5:22pm
Jack Sparrow View Drop Down
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 13 at 5:41pm
more on the subject here: http://www.boatdesign.net/forums/boat-design/halyard-locks-reduce-mast-compression-5968.html
winging it View Drop Down
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 13 at 6:44pm
I am tempted to do this on my contender.  The wire halyard is fraying and keeps jamming in the sheave at the top.  I know the sheave will need replacing anyway, but this sort of stuff is so much easier with a decent line and an external halyard.  Good or bad idea on this class of boat?  it's a carbon spar.
edited to say if yes what line would be best?
Edited by winging it - 14 Jan 13 at 6:45pm
PeterG View Drop Down
Post Options Post Options   Quote PeterG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 13 at 7:07pm
I had a discussion about this recently, in relation to being able to seal the mast on a Contender and make a slight improvement to the rate of inversion. That would be a benefit, but a negative that was pointed out to me was that, sailing as we do from an exposed beach, there are times (thankfully rare) when you can get caught out by a rising onshore wind and break on the beach, when it's very useful to be able to part lower the main. Messing around on the foredeck in those conditions trying to unlock your main might prove a bit interesting! OTOH, if you sail mainly on ponds then it probably shouldn't be an issue.
Peter
Ex Cont 707
Ex Laser 189635
DY 59
robin34024 View Drop Down
Post Options Post Options   Quote robin34024 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 13 at 7:39pm
i have seen people with a cleat at the bottom of the mast too, so you can part lower the sail without too much fuss.
Bootscooter View Drop Down
Post Options Post Options   Quote Bootscooter Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 13 at 8:00pm
My new (to me) OK has a halyard clip at the base of the mast - blue-top needlespar to fairly stiff, and a sail cut to match.  Presumably if I changed it to a clip up the top it'd change the bend characteristics and mess up the sail?
tick View Drop Down
Post Options Post Options   Quote tick Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 13 at 8:10pm
On the C2 Byte there is an open cleat at the mast head. Just locate the halyard in it and cleat. To release just stand at the front of the boat and flick it out. It can jam if you use too much cunningham however.
