After capsizing |
Owenfackrell ![]() Posting king ![]() Joined: 19 Jul 10 Online Status: Offline Posts: 129 |
![]() ![]() ![]() ![]() Posted: 02 Jul 12 at 11:14am |
I capsized my dart for the first time this weekend. I managed to get her upright after a few goes; now that I have done it I’m sure I could do it easier next time. When I went over I fell on to the sail which caused the bottom 3rd or so to pull out of the luff grove on the mast. This wasn’t too much of a problem this time as I was just coming in but if it was any other time then it could. Now my question is would you just go to the nearest land able shore and drop the sail and re-hoist or just do it afloat. I sail on Southampton water/The Solent. |
you need to develop an dive aft of the sail...you were probably lucky that it pulled out the track, as the alternative is you going through it. I would imagine a multi with two people should be able to re-hoist afloat....If it was a singlehander i would expect you to have to make for shore if there was any real sea state
Musto Skiff and Solo sailor
Glad you got it back upright ok. Its good to knock them over once in a while and remind yourself thats its not that difficult to right.
I'd suggest that if its just pulled out slightly, then sail in and sort the main out. I guarantee that if you drop it afloat with the intention to put the sail back up then it will play up and cause you hassle. The hook and eye system on the Dart main and jib is a neat idea, but think of the amount of times putting the sails up has caused you grief on dry land and imagine if you want that whilst drifting over the shipping lane in front of the red funnel!! There are loads of beaches for a quick stop, so I'd do that. How is your main? Is the bolt rope a bit worn? That may be why it pulled out? Might be worth dropping in to a sail maker to get it checked out
The red funnel passed me as it happened. I think alot of it is to do with waiting a bit longer a, for her to swing into the wind and b, for her to actually come up.
My main was with Grant Piggott over winter and he didn't mention the bolt rope as needing doing. I did manage to twist and land back first onto it.
It does take a bit of patience with the Dart!
I'm sure the bolt rope is fine. They would have probably mentioned it. The other thing to look at is the track on the mast. The groove can be a bit too open sometimes and might allow the sail to pop out. That is easily resolved by pinching it back closed a bit with a good set of grips. Obviously don't close it up too much otherwise the sail will stick when hoisting. Happy sailing - very jealous of you being out on the water. My boat hasn't got wet since Feb.....the joy of working overseas ![]() |
Fitzer ![]() Newbie ![]() ![]() Joined: 04 Jul 12 Location: Rep. of Ireland Online Status: Offline Posts: 7 |
Photsterity [COLOR=RED]FONT=Verdana[QUOTE=Username]
