Topper topaz vibe singlehanded? |
piccolo ![]() Newbie ![]() Joined: 10 Sep 11 Location: Midlands Online Status: Offline Posts: 6 |
![]() ![]() ![]() ![]() Posted: 10 Sep 11 at 11:39pm |
Hi, are these boats any good, thinking of hiring one out at a nearby club, as my one is a bit limited...
Most likely i will be sailing it single handedly, but depends whether i can convince my sister to crew! I only weigh 7 stone! In anything other than light winds, will i just end up capsizing? This i don't mind that much, but how easy are they to right? Is it an oversized topaz? I have sailed fevas and visions both helm and crew, without looking at the stats, how do they compare? I don't mind if it's generally not fast, i will be using it to perfect techniques rather than blast around on! |
If you are that light, then yes you will capsize and struggle. I doubt they will let you sail it singlehanded. I'd suggest finding a crew or crewing for someone else.
It's not a desparately powerful boat, you might be able to singlehand it in light weather. How light it needs to be just depends on your level of experience. I'm sure I was quite light when I first singlehanded an Enterprise as a kid.
Finding someone to crew for you might be a better option, especially if you want to get the kite up. If it's a borrowed boat, you have to repsect their right to say no of course. Also, is the layout OK for singlehanding?, you have to be able to reach the jibsheets etc. |
