VHF radio & aerial on a rescue rib |
![]() ![]() ![]() ![]() Posted: 06 Sep 10 at 8:14pm |
I don't think having the aerial within peoples reach is an
issue, my local scout group has an XS Rib with a built in VHF, and the aerial is right on the console, a few inches from the wheel. No one has ever been hurt by it. Edited by Mister Nick |
didlydon ![]() Far too distracted from work ![]() ![]() Joined: 15 Oct 08 Location: Margate England Online Status: Offline Posts: 280 |
Depends how you wire it up..... The right side of the isolation switch of the battery kills the power to everything.... |
Vareo 365
blueboy ![]() Really should get out more ![]() Joined: 27 Aug 10 Online Status: Offline Posts: 512 |
Hmmm.....salt-water proof microphone? |
Problem with fixed installation is crews forget to turn
them off = flat battery next time you want the safetyboat. |
Garry
The one we have on our rib cost about £50 for the ariel but is sooo good it beats others, I'll try and find a link
Right..... update.... Spoke to Icom who reckoned it
wouldn't be a problem - Only happens on high frequency stuff apparently... I thought it was cobblers but wanted to check... Yep, obviously, the higher the antenna the greater the range... As we don't want to clutter the boat with a mast that'll get in the way I think on the console is OK... We thought a fixed in the boat job would be good idea in that it's always with the boat & "charged up" - if you know what I mean! |
Vareo 365
As long as you transmit on the same power as a handheld there will be no problem with the antenna. You can hold the antenna on a handheld so why is it different with a fixed unit. Why are you going for a fixed unit in a rib? If you on the sea it is not so easy to wah the salt off. As far as ariel positioning goes to improve the signal go as high as possible. Just been on a flotilla holiday where the lead crew always used a handheld for mooring. If you were any distance away you could not hear them but you could hear the other yacht used a fixed unit and mast head ariel. |
I Err thats a load of rubbish.
The club ones and my own rib are all positioned on the console, no issue of "burning" yourself as they dont even get hot. Thats the first I have heard of it. If you want me to ask others let me know and I'll throw this out at the pub. |
Hi All. I've been tasked with fitting a fixed radio & aerial to our rescue rib. (Previously we've just used a handheld.) We're getting a nice new Icom & also a Vtronix raider aerial suitable for a rib. I planned to fit the aerial somewhere to the front of the console, but on doing a bit of research on tinterweb, it's not recomended fitting it where people can touch it as you can get burns from it if transmitting at the same time!
Vareo 365
