New Posts New Posts RSS Feed: Moth rudder blade
Moth rudder blade
Calum_Reid View Drop Down
Post Options Post Options   Quote Calum_Reid Quote  Post ReplyReply Direct Link To This Post Topic: Moth rudder blade
    Posted: 17 May 05 at 8:51pm
Keith i thought u were keepin the normal foils aswell or u a 100% convert now!
Chris Noble View Drop Down
Post Options Post Options   Quote Chris Noble Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 05 at 6:16pm
sounds like a similar problem to some older penultimate 14's, you need to sail the boat flat to reduce the weather helm, it will constantly give an upwards thrust, due to the nature of the hull, unless its sailed flat most of the time. It shouldn't need a T foil rudder to pin the back end down as its one of the wider designs. As with all moths its just going to take some getting used to...
FOR SALE:
7BOS View Drop Down
Post Options Post Options   Quote 7BOS Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 05 at 4:59pm
Sounds like the right rudder for the boat, not saying it is the correct size!
The rudder has no effect on those old Magnums unless they are sailed  flat. So if you say it is not working, the boat is not flat.
Keith View Drop Down
Post Options Post Options   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 05 at 4:44pm
Your rudder does not sound like the correct blade for a mag 6.
It wont have T foil but should be deeper than 2 feet.
I have recently updated my Moth to fit Hydros and have my old conventional foils including T foil rudder in dagger style stalk available if you interested.
Let me know if you are interested.
Keith...
Keith...
Stefan Lloyd View Drop Down
Post Options Post Options   Quote Stefan Lloyd Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 05 at 8:18am
I had a Magnum 6 at one time and from what I remember, the rudder was similar to what you are describing.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 05 at 2:03am
You want to get to the Moth Yahoo forum and get a definitive answer, but if you mean two feet in the water it doesn't sound totally outrageous to me.
Bobbins View Drop Down
Post Options Post Options   Quote Bobbins Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 05 at 8:29pm
Hi folks
Recently acquired a magnum 6.  Finally got it on the water last night (proving the worth of drysuits in the process...) and had a great time.  However, blade on rudder is only 2 foot by 6" (not T-foil or anything, think 20 years back).  Is this normal for old moths?  Seems tiny and requires a fair solid shove to get the boat to respond in light winds.  Any thoughts?
Cheers
Rob
www.fastsail.org
Fireball GBR 9476
