New Posts New Posts RSS Feed: getting back in the boat
bert View Drop Down
Post Options Post Options   Quote bert Quote  Post ReplyReply Direct Link To This Post Topic: getting back in the boat
    Posted: 11 Jul 10 at 8:16pm
Carrying on from a post by JRW1019 about BA`s & being Knackered
I had a similar experience with my 100,I like a idiot I fell out to windward in lightish winds & the boat turtled so no problem climbed on the hull & up she comes Bl''Dy CB so slippy that I couldn`t get on to it & over it goes’ again.
So second attempt from a turtle because the CB floats a tad high & I end up in the water with a boat that’s up right but when I tried to get in the boat the BA got in the way & I couldn`t get back in - bugger I said,
So this left me with a problem what is the best way back in from the water ? ( never had this problem before ) I tried over the side - front section & rear ( bloody strop).
At the end of this session I was pulled into the safely boat ( thanks fellas ) completely done in & then sailed back in to the shore after a quick rest.
End of sailing for the day.
So what is the best way back into the boat from the water?
Ideas will be practiced if not too inpolitie
Phantom 1181
AC-227 IC 304
blaze / halo 586
Sailing4Life View Drop Down
Post Options Post Options   Quote Sailing4Life Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 10 at 8:26pm
Pull ups and swimming, pull ups fo you have the strength
to pull your weight (and all that wet sailing gear) into
the boat, and swimming so you can kick your legs really
hard to get back in.
Personally I have never had this problem with or without
BA, as long as you have it done up properly its not an
issue.
Rs600 + many others
luca View Drop Down
Post Options Post Options   Quote luca Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 10 at 8:32pm
One day, I was sailing in light air off Valencia, and the mainsheep popped
out of the cleat. I fell in the water and the boat capsized, and with the
main stuck between the runners and me at 120 kg and tired as hell, I
couldn't get back in the boat. It kept tacking and falling over on me, and
as I laughed exhaustedly, I began to get a bit worried. An America's Cup
skipper and silver medal winner drowning in a force 2 during a hot
Valencia summer day - the thought that this might be the end of me just
made me laugh harder as I tired even more.
Just then, I heard a small motor and looked up to see a RIB with a pitying
Optimist coach looking at me, desperately hanging on. "Do you need
help? You shouldn't be out here if you don't know how to sail..." He
pulled me onto his RIB and sailed my D-One back to the dock. It was an
ignominous beginning to the D-One, but since then, how things have
changed!        just to make sure you do not feel like the only sailor that
has got probs...with the d one we have got read of the schrouds and with
the sail further than 90 degrees no probs...well with the 100 really i
wouldn know but surely you can find a way...good luck luca
G.R.F. View Drop Down
Post Options Post Options   Quote G.R.F. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 10 at 8:50pm
Bert had exactly the same problem to day, in fact I had a nightmare.
First I found I couldn't hold the 100 on a tight reach with the
small sail and went in twice.
But had the devils job getting back in.
A fresh force four on the open water, I'd right it, then over it would go, I
try to get in over the side which i could do easily enough, but it just came
straight over on top of me to weather.
3 or 4 times then one of the rescue guys jumps in to hold the other side
whilst I got in.
Missed the start, sailed the first beat, made the mark everything going
well considering, my windward work was the best I've done in a strongish
breeze, no irons, no missed tacks, but bearing off to go round the mark, I
could go deep O.K. but the mark was off on a tightish beam reach and
once again the boom grounded as a swell lifted the wing and despite
everything in I went and the same all over.
Very frustrating, I was totally knackered having seriously tried several
times not wanting to use the rescue guys again, but to no avail.
After that I baled and sailed back to the beach, not wanting to
monopolise the one rescue boat we have.
After a bit of boat park debriefing I heard that maybe dumping the kicker
offwind may not have had me consigned to the drink in the first place, but
even so, I'm going to go in sure enough sooner or later and I'm now
concerned about this question.
One of the guys did suggest i think about it like water starting a board,
i.e. sheeting in as I get in, but the boat is normally head to wind..
It's a problem, and I'm not normally that iffy getting back in the boat. I
usually get in first and help whoever else is around in. Today I wasn't at
all bulked up. The slippy centreboard is going to get waxed for a start,
but that won't help the thing coming over on top of me.
Oh and yes I did get in over the back one time, which is easier and fine,
but getting the boat to stay upright head to wind, without someone on the
nose in wind and waves is pretty damn tricky if not impossible on your
jack jones.
Edited by G.R.F.
Dougal View Drop Down
Post Options Post Options   Quote Dougal Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 10 at 8:58pm
GRF, clearly not watching the football either!
bert View Drop Down
Post Options Post Options   Quote bert Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 10 at 9:00pm
Thanks Luca -- very similar apart from the Pitying Oppy bit - funny how the world is a great leveler of people isn`t it but that`s the fun.
As to finding a way,I am sure that I will,30 years of sailing & haven`t drowned yet! But I have never had this problem before.
I am considering fitting a small foot loop arrangment for entry over the transom.
Rockhopper :- total time in water 20 minutes turtle twice should have just left it upside down & got my breath back but the board was so slippy it was hard to hold on to never mind climbing on to but certainly the way to go if possible.
GRF :- I only went over about twice but tried to access the boat from the water from every direction I could think of but the boat didn`t seem to allow access over the side as easily as for example a Phantom / 300 & if I could have got onto the board then I would have proberly got it upright OK - not sure that waxing the board is going to be fast.
Radixon:- that type of BA might help but NO WAY could I wear that & be seem in public ever.
As to the foot loop idea I think a rope from the rudder post going round a pulley back to a sercure point by the transom is viable on a take up system this way I could put my foot in to it & gather the main sheet at the strop to pull the sail to the centre line & gave myself a leverage point the boat would sink abit & depower hopefuly making life easier
I feel I should say that this happened about 3 weeks ago & on the sea small swell but as a pond sailor it did not make it any easier.
Edited by bert
Phantom 1181
AC-227 IC 304
blaze / halo 586
Rockhopper View Drop Down
Post Options Post Options   Quote Rockhopper Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 10 at 9:01pm
try and get on the plate so you can get your leg over or if its on its side climb up the inside the leg over the top onto the plate which every way you do it you have to get on the plate otherwise its over the transom or grab the toe straps and pull yourself in.
Well this is how i do it i tried it out first hand at this weekends open massive windshift had the boat capzise on top of me and i climbed up the inside over and over onto the plate total time capsized about thirty seconds before sailing away again.
2004 national champ Laser5000
Jack Sparrow View Drop Down
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 10 at 9:22pm
All I can say G.R.F is that when I sailed the 100 with big rig in big
breeze in Minorca I had the same issues. I'm a fit guy, but small 5'3"
70kg and no muppet in a boat and I couldn't get back in. The 100
would come up to 45 degrees very easily, too easily, so easily you
can't get up on to the board before it is half upright. You grab the
righting strop pull it fully up right, then you try and get in and it comes
over to weather, you go around the back to get in. It capsized again.
As for the answer? Other than not designing the boat with wide
buoyant wings in the first place I can't really say, as I haven't spent
enough time with the boat. But I suspect there may not be a solution.
radixon View Drop Down
Post Options Post Options   Quote radixon Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 10 at 9:27pm
Bert
Would a BA like this help
I know its had its threads in the past but if its because of the bulk then may be worth considering.
We have a young sailor who is unable to pull himself into a Tera, ok not a massive boat but he was unable to grab a toe strap. The solution for him is to grab the mainsheet and sheet in then to let go at the last minute.
I think a foot loop would cause issues when normally sailing.
Lukepiewalker View Drop Down
Post Options Post Options   Quote Lukepiewalker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 10 at 9:30pm
Having generally avoided capsizing, the only advice i will offer is to let the kicker off to allow more headroom and to ease the power in the sail a bit. Although I always found my first National 12 was particularly conducive to easy reboarding on account of the fact when it was back upright the transom was virtually underwater and you could just about swim in...
Ex-Finn GBR533 "Pie Hard"
