New Posts New Posts RSS Feed: Planing
Planing
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Planing
    Posted: 22 Apr 10 at 3:37pm
Frank Bethwaite either misunderstands or choses to mis-represent what planing is. It has nothing WHATSOEVER to do with sailing faster than "hull speed". There is no magic Froude number at which planing begins.
As unhelpful as it is to real life, planing 'begins' when there is a stagnation point on the underside of the hull.
ellistine View Drop Down
Post Options Post Options   Quote ellistine Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 10 at 3:20pm
Originally posted by ColPrice2002
What Dinghy is the OP
using?
A 4 Tonner I believe, but the context is a tuning guide,
so the creator of the tuning guide had a speed range in
mind where certain settings need to be changed, so all
she needs to know is when that point is reached. A
discussion on what *is* planing would be better placed in
the development forum...
Exactly. It related to jib sheet tension. When to keep it
tight to aid pointing against when to let it off some to
sail free. It was suggested that when planing there may
be some advantage to sailing freer but a bit more reading
suggests that there may not be much of an advantage doing
this in a 4000.
Still, at least now I know when we're (perceived to be)
planing - other than when the daggerboard sings to us.
Edited by ellistine
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 10 at 2:52pm
What Dinghy is the OP using?
A 4 Tonner I believe, but the context is a tuning guide, so the creator of the tuning guide had a speed range in mind where certain settings need to be changed, so all she needs to know is when that point is reached. A discussion on what *is* planing would be better placed in the development forum...
ColPrice2002 View Drop Down
Post Options Post Options   Quote ColPrice2002 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 10 at 2:45pm
Yup,
Really much more complicated, but some dinghies have an obvious transition -
My old Firefly had a noticeable transition - usually needing a significant weight shift sternwards - between non-planing & "planing".
My Solo has a trasition - but this is less severe (differnet hull shape) - however there are at least 2 different stages - I reached stage 2 in (non-forum) gusts of Force 6 - mega amounts of spray!
On the other hand, the Merlin seems to lift (stage 1) almost imperceptibly.
Colin
ham4sand View Drop Down
Post Options Post Options   Quote ham4sand Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 10 at 10:15am
yes but i was just saying it was the trough of the boW wave, not the crest, sorry matt
John Hamilton
cherub 3209 - anatidaephobia
laser 176847 - kiss this
Matt Jackson View Drop Down
Post Options Post Options   Quote Matt Jackson Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 10 at 8:11am
Originally posted by ham4sand
i rem,ember more now... i think its when the boats stern overtakes the trough of the bow wave....according to frank bethwaite
Isn't that what I said?
Originally posted by Matt Jackson
...read an interesting definition in my Tasar manual years ago which was based on the position of the bow wave relative to the hull where... fully planing is when you overtake the bow wave...
As it was from the Tasar manual I think our sources are the same as well.
Edited by Matt Jackson
Laser 203001, Harrier (H+) 36
Post Options Post Options   Quote ellistine Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 10 at 9:51pm
For a lot of people the point is where the wake
goes smooth and you get a wake line from the chines
meeting somewhere aft of the transom.
Had a look out for these to night and they definitely
appear as the speed starts to build. I shall keep an eye on
them
Post Options Post Options   Quote ham4sand Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 10 at 8:57pm
John Hamilton
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 10 at 7:16pm
Boats which cannot plane are generally subject to the rule described, but boats which can plane will have a gradual transition between non planing and planing, which suggests that hard and fast rules on jib settings would be a mistake.
Planing is one of those things which is difficult to define but blooming obvious when you do it!
Post Options Post Options   Quote ham4sand Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 10 at 2:52pm
there is something about it in highperformance sailing....not sure the exact details as havent got it with me but i think its something to do with passing the quarter-wave or something like that
John Hamilton
