New Posts New Posts RSS Feed: Damaged wood
Damaged wood
tomoore1 View Drop Down
Post Options Post Options   Quote tomoore1 Quote  Post ReplyReply Direct Link To This Post Topic: Damaged wood
    Posted: 28 Mar 10 at 7:31pm
Is there a way to restore water/UV damaged wood? The old (1947) Firefly I am doing up has quite a few lighter or darker patches. Is there some way these can be restored to their original (or at least an even) colour? Or is the only way forwards painting?
Also, what is the largest area of hull which can be soft safely? I have a 5cm square patch on the hull (not stood on as its under a buoyency tank). Can I just put some epoxy on the inside to stiffen it up and make sure the outside is sealed?
Also, any tips for re-glueing a rudder blade together?
Cheers Tom
Restoring Firefly 517
MerlinMags View Drop Down
Admin Group
Admin Group
Post Options Post Options   Quote MerlinMags Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 10 at 10:29am
Wood that has gone dark can be brought back with Oxalic Acid. It's a bit tricky to get hold of as it's actually a poison. Beekeepers use it.
Some chandlers may stock it, and I've heard wood suppliers keep it sometimes. You can also mail order - this link might work:
http://www.jpennyltd.co.uk/
ASok View Drop Down
Post Options Post Options   Quote ASok Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 10 at 11:14am
Rub rhubarb leaves on there. High in oxalic acid!
Graham T View Drop Down
Post Options Post Options   Quote Graham T Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 10 at 11:23am
Last oxalic acid I bought came from e-bay - I was surprised
at how easy and cheap it was to get hold of. Mind you I
have attempted to use oxalic acid several times over the
years of owning old wooden boats and have never been very
impressed with the results despite its reputation as the
stuff to use.
Osprey 55 "Tebutinnang"
Osprey 1245 "Two Bob Bit"
Miracle 1358 "Thumper"
Post Options Post Options   Quote tomoore1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 10 at 2:46pm
Cheers for the help so far guys.
Is there a way to get rid on the grey patches then? The darker stuff is only a small amount of the overall damaged area.
