Self Tacker |
![]() ![]() ![]() ![]() Posted: 14 Mar 05 at 8:56pm |
Hi, I am looking to upgrade my i14 to self tacker and was wondering if any one has an old track or slider (or both
![]() If any one has some old track or sliders, or any information on other self tacker systems it would be very helpful!! |
Oh yeh i forgot to mention - I can get the sliding track of an old dart
real cheap with the slider - does ne one know if a mainsheet
slider/tacker would work or is it 2 chunky to be worth while?
Be a big lump the mainsheet one. Probably more friction too.
One tip, if at all possible get track without any holes in. If you have the usual pre drilled track when you bend it to shape it tends - of course - to bend most where the holes are,and you end up with a ratchet jib track which is less than desirable. |
Thanks for that jim c, unfortunatley the dart track is predrilled so its an unlikely option now!
I wonder if instead of a track a strop (like a mainsheet strop) would work?
Garry
Yeh it would work but only straight across a boat - it cannot be curved
because it would need support - I am currently looking at using
stainless steel rod to the same effect but it can be bent thus being a
no go grab rail!!
When my Self tacker track broke I replaced it with a peice of aluminium tube which had previously been a cloths rail. With a U bolt as a slider. It worked for a few days but tended to bend in the middle quite a bit. and had too much friction.
Spot192 ![]() Really should get out more ![]() ![]() Joined: 28 Nov 04 Location: Germany Online Status: Offline Posts: 833 |
what kind of 14 do you have? mate tried the cloth trail, but it relly didn´t work very long, even in our light winds.
sargethesailor ![]() Newbie ![]() Joined: 21 Feb 05 Online Status: Offline Posts: 12 |
Granite you always were a skinflint! How fitting that you should have studied in Aberdeen!
Ive got a benedict 7 hull thats been modifyed by ovington and has
extended wings(racks like the new ones but solid like a 49ers), and a
prodder. It currently has a spaceframe with a open foredeck but we are
in the process of replacing that with a carbonkevlar fibre foredeck.
I was wondering if a system along the ideas of the clothes line but using solid steel rod in stead of soft aluminum clothes line would work! - its certainly hard enough to bend into shape! How do you mean bend in the middle surely there is hardly any sheet tension as the sail passes from side to side? Edited by ssailor |
