control lines |
![]() ![]() ![]() ![]() Posted: 14 Mar 08 at 9:25pm |
Hi Can anyone point me in the direction of article on the net on how to make continious control lines,what ropes to use & what tools that are used. I have checked out rooster artile on the use of fids ,the article is very good but it appears that the line is double thickness for a small lenght & is not for control lines. Very good article though
Cheers Edited by bert |
Phantom 1181
Splosh ![]() Far too distracted from work ![]() ![]() Joined: 13 May 07 Location: United Kingdom Online Status: Offline Posts: 497 |
Basically you need a long bit of rope and some fids What you need is the RS splicing guide... hang on, and i'll find it.
RS300 - 346 :D
RS300 - 346 :D
Thank you A fast & good service.
Phantom 1181
RS300 - 346 :D
if ur splicing small ropes. then those fids dont work. u will need a needle
TWO FRANK-Hunter Impala
Weird? I've spliced 3mm rope with the same fids as them, and that rope in my eyes was small |
RS300 - 346 :D
ok. bov said that u couldnt get them under 3mm i was splicing 2mm trap lines.
http://www.rs300.org.uk/index.php?option=com_content&tas k=view&id=85&Itemid=29 Is an article on how to make a 300 continuos kicker! |
Also try this Link: |
