Vectran forestays |
Page 123 4> |
![]() ![]() ![]() ![]() Posted: 14 Aug 07 at 6:35pm |
The luff of my jib is a stiff wire that forms the forestay once it's tensioned. But every time we roll up the jib to store it, the wire twists crumpling up the foot of the sail and the mylar is sufferring.
On the basis that the jib halyard (and hence forestay tensioning system) is all Vectran, I tried a length of 4mm marlow excell V12 as a forestay when sailing without the jib once, and it seemed OK (but I used it doubled and kept the lazy stay attached - just in case) . Overcautious surely as this stuff has a 1.6 tonne breaking load! Has anyone tried a vectran forestay instead of a wire one? Is it safe? If so, why are we still using wire? |
Javelin 558
Contender 2574 |
I would have thought that would be fine - it's a good question. I always thought V12 was lower streatch and stronger than D12 but this seems not to be the case looking at the data on the Marlow site. http://www.marlowropes.com/public/pageManager.cfm?page_id=15 6 Why choose V12 over D12 or vice versa? What is the % extension & breaking loads of halyard wire compared to the V/D12? Also - why is Vectran so much more expensive when it seems it has similar properties? (I guess they don't have similar properties ... Edited by Guest#260 |
It's becoming common in some high performance development classes such as International 14's and 12ft Skiffs. The advantages are that it's lighter, and sometimes stronger. It's also cheaper by the metre, and you save money have terminals or eyes fitted. And it's easier to cut if you get trapped. The disadvantages are that for equal breaking load the string will have a bigger diameter, and therefore greater windage. The string is not UV resistant, so needs to be replaced every 6months if you leave your mast up outside. The string is not wear resistant, and often wears out where the string passes through spreaders. The latter two problems can be overcome to a certain extent with an "outer" but this again increases windage. Edited by Strawberry |
D12 is dyneema,lighter and a bit more chemical resistant than V12 which is vectran. Other than that - pretty similar. I only used V12 because I had a load of it left over from making a decent jib halyard (the supplier needed two attempts to get the length right and sent double what I needed) It's certainly dead easy to put eyes in - just needs a fid (or a modified chopstick in my case) and some whipping twine. UV isn't a problem if it's inside the jib luff -though I guess I'd better worry about the halyard which is out there on the mast rain and shinem (50% strength loss over 3 years apparently... and it would be nasty if it snapped! |
Javelin 558
Contender 2574 |
spin cycle ![]() Groupie ![]() ![]() Joined: 06 Oct 06 Location: Scotland Online Status: Offline Posts: 43 |
Nick I think I had 5 or 6mm vectran put on the 14. This approx 4 years ago so ropes have developed but the reason for this was 2 fold, it not just breaking strain but the elongation under load that counts and you need to go up to 6mm to get the same as dyform for your forestay. The other advanatage at least it gives you some leeway if the forestay is left out in the sun.
Given the chemical attack issue is not that big why pay double for vectran? |
Dyneema, in common with most ropes, suffers from creep - that is, it will stretch not merely when initially subjected to a load but also over time, whereas Vectran is much more creep resistant. So for things that are (or should be) frequently adjusted, Dyneema is fine, but for standing rigging which needs to maintain its length throughout a race, use Vectran. I'd have thought that Vectran would be great inside a jib luff, so long as the diameter was well-chosen, but it is probably harder to tell when it has been damaged (we replace wire if there are any loose strands, after all), so catastrophic failure could be more of an issue (it's easier to cut than wire too, after all). |
That's not what the data on the marlow site says ... they both extend about 3% at 50% max load .... |
Yes, their stretch characteristics are similar, but creep is different.
Explain ... |
Page 123 4> |
