Idiots guide to gelcoat repair;Help Pleas |
Page 123> |
limey ![]() Groupie ![]() Joined: 21 Dec 05 Online Status: Offline Posts: 46 |
![]() ![]() ![]() ![]() Posted: 23 Mar 07 at 5:54pm |
My nice new shining Laser just slipped off the trolley chipping the gelcoat on the back corner of the stern.Can someone explain in very simple terms the best way to repair it so i have a nice shiny botton again. thanks
im not sure but i think repairing corners can be a nightmare compared to flat surfaces, dont mean to put you off. please note i have never attmepted any gel coat repir, ive just been listening to other people. Edited by mike ellis |
Also International 14, 1318 |
Buy the gell coat kit from laser, use tape to get a smooth finish and shape desired, then use very fine wet and dry to get finish, i have done it loads of times and you can never see the repair!
Plastic Padding gelcoat filler works wonders.
Mix it up Stuff it in the hole Wet 'n' dry till smooth (can use tape at the previous step to reduce sanding) Re-wax the surface to get the shine back and job done Edited by Worthy |
Tell me again where the damage has occured! Ease of repair depends on extent of damage quality of aspired repair Time available. Most Lasers are Vela Grey. Thi does not match Mag Marine Gelcoat. However, if the reapir is small it's hardly glaring. Mix and apply. Use selloape or orher to mould fille to damage. Sanding is the bugger. Best of luck! |
Thanks for the advise but a very simple step by step guide please. I buy the gel kit ,add the hardener ,then what...............!!!! The damage is to the gelcoat where the transom meets the underside (just next to the rudder fittings)
RS700 GBR922 "Wirespeed"
owain ![]() Posting king ![]() ![]() Joined: 11 Jun 05 Location: United Kingdom Online Status: Offline Posts: 142 |
probably best getting the gelcoat from rooster or laser (phone steve at rooster, and he'l tell u what 2 do) the plastic padding stuff wont give you a perefct colour match. im assuming your laser will be vella grey? Edited by owain |
Owain H
49er GBR055 Fireball 14291 Plymouth Uni Sailing Club & Chelmarsh Sailing Club |
My friendly boat builder advises against wet and dry as it thins the gel coat around the patch. Scrape the mend flat with a stanley knife blade apparently!
Javelin 558
Contender 2574 |
Put masking tape aroung the reapir. That way, when you wet&dry, you won't affect the surrounding gelcoat. Scraping with stanley blade is of limited use because; a. How many pencils have you perfectly sharpened using this method? b. Gelcoat chips at the first sign of trouble (stanley blade). You'll be straight back to square one. |
Page 123> |
