A trailer Q |
RedOnesGoFaster ![]() Newbie ![]() Joined: 14 Dec 05 Online Status: Offline Posts: 10 |
![]() ![]() ![]() ![]() Posted: 04 Oct 06 at 6:11pm |
Does anyone know offhand if an enterprise road base is likely to fit an RS200 trolley?
If not a solo? I konw you can only go by the standard ones but any input would be helpful, as supposed to be going to the 200 inlands this w/e and my road base is getting repaired.... Thanks in advance! |
Any trolley will fit any base with enough ratchet straps...
RS700 GBR922 "Wirespeed"
Ian99 ![]() Posting king ![]() Joined: 07 Apr 05 Online Status: Offline Posts: 138 |
Assuming width isn't an issue, as long as you put the trolley so the trolley wheels are in line with the road wheels (you'll have to take the trolley wheels off) an ent trailer should be fine.
You will need to tie the trolley to the trailer though - use a heavy duty ratchet strap, wrap it round each bit of the trailer and trolley A-frame and then wind it on really hard. A second bit of rope should be used to tie the trolley forwards. Then tie your boat on as normal. |
