Twin Wire Helming |
Lucy Lee ![]() Far too distracted from work ![]() ![]() Joined: 17 Mar 04 Location: United Kingdom Online Status: Offline Posts: 276 |
![]() ![]() ![]() ![]() Posted: 25 Jun 06 at 8:20pm |
It won't make it easier but I'd recommend spending some time in a contender. They are well mannered boats that you have to trapeze, so you'll learn the tricks very fast. I 'borrowed' one on a sailing holiday in Menorca many years ago and pretty much had it licked by the end of the week. It won't help with the mind tricks required to helm an assymmetric downwind, but you'll be fine at that if you've been helming from the 'arse on the side' position! |
Fly Cherub!
just make sure to jump clear of you rig wen it all goes wrong or things start getting expensive... i found this one out the hard way
Hee hee thnx
i hope not to break too much |
Greatfully Sponsored By
Exactly as the others have said, and get out there and practice! its only bones and boat you will break
1) Get the crew to take the main. 2) Get decent kickbars so you don't need to use your hands to push off. 3) Start by trapezing really high becuase it makes it much easier to get out. Then drop if you need to. 4) Don't forget to concentrate on keeping the boat in the groove, or you'll piss it in to win'ard. |
It's pretty easy to get used to, I just took my new 14 out having never done it before! What makes it harder is if you have the main led of the floor with the helm steering and doing the mainsheet (like my 14) since you can't do the hand over hand sheeting thing you can do in hiking boats and ned to use the cleat to help. If your crew has the main it is a piece of cake. Also, learn on flat water if you can! A few ways to make it easier: Tacking is the hardest bit, especially if you have a slow/inexperienced crew who doesn't wire to wire tack (like I do) in the boat like the 14. One of you *must* hit the wire before the battens go or you will swim. See higher and faster dvd for how to do it well. Edited by m_liddell |
Get in the strap and send it - sitting on the side and soaking is for Essex boys ...
erm... from my small amount of experience...
In a twin wire boat I would suggest in marginal trapezing make the crew do the monkeying about keeping the boat flat, then when there is enough to wire constantly make the switch and get the helm out all the time (again make the crew do the keeping the boat flat), then when its windy enough to twin you'll already be out there. This applies to upwind as downwind is obviously much more dependant on angles and wind strength etc Downwind you will have a lot more power in the 14 but i normally advise getting the crew on the wire asap and then either sitting comfy and soaking or powering up and going for the twin. It can take a bit of getting used to and its definitely not fast if you are floating out the windward side tiller in hand with the boat 3 metres downwind of you! (been there before too many times!) |
Hi guys n gals,
Just wondering if you had any tips and helpfull sugestions that would make the transition to twinning and steering easier? |
