New Posts New Posts RSS Feed: Laser Vago XD Rig
Laser Vago XD Rig
vago_ballast View Drop Down
Post Options Post Options   Quote vago_ballast Quote  Post ReplyReply Direct Link To This Post Topic: Laser Vago XD Rig
    Posted: 16 Jun 06 at 8:46pm
I have just spent 3 days crewing in a Vago and the helm and I had a real problem on the XD rig of getting the full battens at the sail head to pop through in the (incredibly) light  winds. We have adjusted the batten tension, cunningham and gnav tensions but it took an huge amount of effort to get the sail shaped on the right side. Has anyone had this problem and does anyone have any suggestions to overcome it.
Thanks in advance of your help
Isis View Drop Down
Post Options Post Options   Quote Isis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 06 at 8:53pm
Not enough mast bend may be a problem... Its not something you want to be changing just to pop the battens though really.
If you cant get them to pop even after loosening the batten tension its probibly more of a technique problem I suspect.... You often need a sharp flick as you come up after the tack to get them to pop which is something beter shown than explained.
combat wombat View Drop Down
Post Options Post Options   Quote combat wombat Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 06 at 8:56pm
On my B14, in light winds it is a case of a bit of kicker, (crew in front of mast in these winds), crew rolls the boat hard through the tack, then helm crosses boat, eases mainsheet, grabs the mainsheet from the block and falls heavily onto the windward wing.  This sheets in the main and jerks the boat upright, and the battens pop.  We have a light winds mainsail which we have eased off the top batten, it pays to have some outhaul on as well.
Obviously you don't have wings but the key is sitting down hard as you sheet in, with the crew ready to stop the boat going over to windward.  Be brutal, it may shake the wind out the sails but thats faster than attempting to sail with the battens inverted!
CW
B14 GBR 772
olly_love View Drop Down
Post Options Post Options   Quote olly_love Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 06 at 10:00pm
talking about mast bend. i cannot understand on that boat how it has a untapered mast.  does it not need it cause it has a fat head mainsail.
was out the otherday in bout 15 knots and it seemed really fast however when we speed checked it was wuite slow.  has a massive problem with the bow going high. no mattetr where u sit
not a race boat like laser said more a training boat
TWO FRANK-Hunter Impala
m_liddell View Drop Down
Post Options Post Options   Quote m_liddell Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 06 at 11:24pm
Cost I'm sure.
Post Options Post Options   Quote olly_love Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 06 at 11:31pm
must be. cause it is a large section looks built to last. but the quiality of the rest of th efittings is up to laser quality...... crap
Isis View Drop Down
Post Options Post Options   Quote Isis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 06 at 11:35pm
etc etc
gonzo View Drop Down
Post Options Post Options   Quote gonzo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 06 at 6:11am
still plastic never going to get a high perfromance plastic boat are you
Supposed to be a more high performance than a feva type of boat for clubs that are trying to promote high performance dinghys.
Go Big or Go home or sail a 49er!!!
Post Options Post Options   Quote vago_ballast Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 06 at 7:15am
Thanks for all your suggestions.
We'll give them all a try next time we're out
Lucy Lee View Drop Down
Post Options Post Options   Quote Lucy Lee Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 06 at 7:00pm
As a crew I find that giving the cunningham a sharp tug when the helm is trying to pop the battens often helps. Just have to remember to have it cleated on the 'old' side before the tack/gybe and not to cleat it in too hard after the manoeuver...
Fly Cherub!
