Tornado average crew weight |
Author | |||
far canal ![]() Posting king ![]() ![]() Joined: 01 Feb 06 Location: Micronesia Online Status: Offline Posts: 110 |
![]() ![]() ![]() ![]() Posted: 13 Jun 06 at 2:03pm |
But how would you address it ? Get everyone to hop on the scales before the start of a regatta so they can have their own personal Hcap for that event. Would be a nightmare to administer !
Why not , or as everyone does allready under rule as it is , self certify and if someone doesn't believe it you can be subject to protest , no one checks schrs measurements at events , hurricanes can sail off at least 4 different varients and other boats too in different configurations, with different hcaps.
How long would it take for an entrant to turn up with the their schrs fomula with weight printed up and submitted with entry , if found to be cheating they could be yellow carded (chucked out of regatta ) then red if done again (chucked out of racing that season ) seems pretty simple to me .
Laser 4000's have weight equalisation and don't seem to have any probs running it and it works on self policing , at big events they check top crews , even in keelboat racing crew weights are part of handicap and a self policing and check system is run .
why do cats have to be so backwards , or are they weight discriminists , might just take SCHRS to human rights .
SAVE The WHALE ! just a thought , spose for the skinnys in majority , not their prob. Edited by far canal |
Any forumla will always be "designed to". The Hurricanes have done a fine job in that. Also look at some other boats, they are spot on the "roll over" point to the better number - The Shadow beinga good example! The SCHRS rule is being looked at and will be updated for the next ISAF meeting in the Autumn. A beam factor is currently being considered and will (hopefully) be included assuming the ISAF approve it.
A number of other things are also being looked at too. More info soon (I hope) |
tornado435 ![]() Posting king ![]() ![]() Joined: 05 May 06 Location: United Kingdom Online Status: Offline Posts: 196 |
Don't even start me on that formula.
No handicap for Beam how Hurricanes have proved how to make the most of the formula. Drop a bit of jib, add a bit of weight and hey presto it allows a 21 sq metre kite. all they need now is some beam extensions, free under the rule!!!! |
To make matters worse for fatties in cats , the SCHRS handicap formula rates you at 75 kgs a person !!!!!!!, so fatties at 110 kgs plus (they are out there !) are at a disadvantage before they even start .10kgs is about 1 percent on handicap .
Then you get light b*ggers who are less than 75kgs each getting an advantage on their rated weight . seems a shame a formula that takes weight into account doesn't address this.
It never pays to be overweight in a cat with modern rigs etc .
hurricane ![]() Really should get out more ![]() ![]() Joined: 15 Mar 04 Location: United Kingdom Online Status: Offline Posts: 1047 |
the fact alot of the helms had to carry lead might have had something to do with it!
RIP Olympic Tornado 1976-2007 |
AdrianM ![]() Newbie ![]() Joined: 03 Apr 06 Location: United Kingdom Online Status: Offline Posts: 33 |
So what killed off the F20 class? I would have suited the F20 better but went for the F18 as the F20 class seemed to be dying out (look at nationals attendsance etc).
Edited by AdrianM |
Agree Paul, perhaps time to switch Helm for crew. Never really did understand the "helm is in charge" thing anyway; always a team effort and the crew usually had a better idea of what was going on anyway as I was usually concentrating on waves / shifts / making the boat go fast upwind and then they were driving downwind with the kite. |
Teamvmg ![]() Groupie ![]() ![]() Joined: 26 Feb 06 Online Status: Offline Posts: 99 |
jon, there ain't no such thing as a cat that 'takes' weight. you gotta be down to class min weight if you are to compete. Adjustment for heavier crew does not exist, only adjustment for light crew! I am 90kg and therefore have a very overworked 58kg F18 crew! you need about the same all up weight on a T but its better to have the power[weight] in the crew. Bring back Formula 20 and let the fatties do some helming! [160kg class min weight]
Paul GBR7 |
jon2005 ![]() Groupie ![]() ![]() Joined: 31 Mar 05 Location: United Kingdom Online Status: Offline Posts: 49 |
I could get down to 90kg at a push i guess thats the disadvantege of being 6.6ft tall. In light winds is where i suffer because weight is everything then but as soon as the wind picks up we are away. Is the Tornado sensitive to rig tention and spreader rake ect? And can you adjust it for heaver crews? Cheers, |
