Removing Stickers |
bigum ![]() Newbie ![]() Joined: 06 Oct 05 Online Status: Offline Posts: 32 |
![]() ![]() ![]() ![]() Posted: 09 May 06 at 12:28pm |
My lovely ( fiberglass ) Contender has dinghy park stickers on it going back 10 years. They look horrid! I was going to try to get them off with a hair dryer but realised I may melt the gelcoat or somthing dreadfull All advice gratefully received....
d |
Olly4088 ![]() Far too distracted from work ![]() Joined: 10 Jan 05 Location: United Kingdom Online Status: Offline Posts: 424 |
A hairdryer is the only way to get them off really. Just hold it quite far away so that they heat upslowly and make sure when you are pulling them off you pull them back on top of them so its almost like you are rolling it off
Phantom 1298
Lucy Lee ![]() Far too distracted from work ![]() ![]() Joined: 17 Mar 04 Location: United Kingdom Online Status: Offline Posts: 276 |
Hairdryer should be fine; heat gun now tha's a different matter.... I'd recommend keeping your hand on the sticker while you use the hot air device: if it is in danger of burning your hand it is probably getting a bit hot! |
Fly Cherub!
Good advice, you olny want to warm them up; not cook them |
Hair dryer - no probs. After all you are just looking to soften the glue enough to make it less sticky. Now....Getting rid of any sticky residue that could be a problem as a lot of solvents could damage the gelcoat |
Crew on 505 8780 |
kasey3000 ![]() Far too distracted from work ![]() ![]() Joined: 06 Apr 04 Location: United Kingdom Online Status: Offline Posts: 401 |
Use brasso... that's what I always use to remove stickers and the gunky residue u have left over...
49er 908
Brasso contains ammonia so be careful, but you should be okay Be sure to have a bucket full of water and give the area a good wash down to remove the brasso residue - better to be safe than sorry |
Crew on 505 8780 |
