tiller |
![]() ![]() ![]() ![]() Posted: 18 Apr 06 at 8:05pm |
yeah, register to the message board at www.bu22.co.uk and drop a PM to Pete Lindley. Hes the man to talk to.
Jp Indoe
Maybe run a line across the boat from one gunwale to the other, under tension, on the way wrapping it once, twice or more around the tiller? Would tend to damp out any movement. There's always this solution: http://www.rwo-marine.com/tillerbrake.html but I'm not sure how useful it would be in a dinghy. Maybe some food for thought though... |
To be honest i certainly cant see the class association moaning about any mods you want to install to make the boat easier even if its not within the class rules.
Why not contact the Buzz class association, explain the situation and see if you can convert from a single-tiller extension to twin tillers extensions? The advantage to the twin tiller extensions is that they are mounted to the side of the tiller and not on the top and with rubber joints, they should sit naturally at a position which your dad will find them easily at and it also means the extension doesn't need to be flicked across the boat. Make sure the extensions are long enough that they won't get caught inside the boat though. Thick shock-chord limiting movement of the rudder does work to a certain degree, reckon if it's looped up through the bottom gudgeon and over the top of the tiller directly verically above it, very tightly, it restricts movement of the rudder blade very well. Seemed to work on training sessions on our boat but we have a lighter and probably smaller rudder blade than on the buzz. |
you could replace the pintles with both holes then using bolts and washers just bolt them together and then tighten till it stays inplace. along with the bungy it might work
TWO FRANK-Hunter Impala
does anyone have any ideas on how to make the tiller stiff to turn
because i sail with my dad who had his arm amputated he needs the
tiller to stay in the same place as he puts it so he can let go to move
about the boat (he had his leg amputated as well) cos we go straight
over every time he lets go, its a buzz if it helps, we have tried
bungees but when the wind gets strong the bungee doesn't hold it well
enough
also any other ideas on how to make the boat easier to sail for my dad would be appreiciated but stay within the class rules |
