PY adjustment for non-spin Mirror or Cadet |
| Author | ||
CT249
Joined: 08 Jul 06 Online Status: Offline Posts: 399 |
Topic: PY adjustment for non-spin Mirror or CadetPosted: 02 Sep 22 at 5:49am |
Okay, brains trust; I'm trying to get an idea of the PY adjustment for a small local pram, similar to a baby (8'6") Mirror but being sailed by kids straight out of sailing school. On our little pond I would like them to start off concentrating on the fundamentals rather than being bamboozled by setting and trimming a kite in our fluky winds.
I know in the grand scheme of things an accurate PY isn't a great issue for beginners but if anyone has an idea of the adjustment for a fully-crewed but non-spin Mirror or Cadet, I can use that to give a reasonable basis to make a club adjustment. Because of the fluky conditions the learners on slow boats can actually have some great races. A while ago one of the Topper kids was just beaten for line honours by a 59er, and before that a Topper kid on his first ever race at the helm (coached by his dad chasing him on a Laser) beat the world A Class Classic cat champ on PY; not bad to be able to say you beat an Olympic medallist first time up, not that it made me jealous....
Rupert
Posted: 02 Sep 22 at 6:45am |
It is possible that a tiny boat on a fluky pond is faster without the spinnaker. In a Mirror, singlehanded without a kite is deemed 10 points faster, which is probably underestimating the advantage on our pond. With a crew, I started to be beaten by a Mirror with spinnaker once the breeze got the sail filling properly. As soon as lulls or shifts had it collapse, a spinnaker was fun, but break even at best, unless the team were properly slick.
Paramedic
Joined: 27 Jan 06 Location: United Kingdom Online Status: Offline Posts: 929 |
Posted: 02 Sep 22 at 7:15am |
The couple of small clubs I know that do this give +20.
The faster the boat the more the disadvantage by not using it and theres no universal right answer. +20 may be too generous for a mirror, but a fireball is still crippled
Edited by Paramedic - 02 Sep 22 at 7:16am |
Woodburner
Joined: 13 Mar 15 Location: Folkestone Kent Online Status: Offline Posts: 332 |
Posted: 02 Sep 22 at 9:11am |
I might be able to help, I did some calcs back when I was messing about with Peakys "Fuller number" if I can a) find the computer I did it on and b) Those numbers are even relevant to todays situation I got stuck on the differences between Syms and Assyms if I remember correctly, I'll have a look and report back.
Woodburner
Posted: 02 Sep 22 at 9:36am |
OK found it, so would need the following. Boat Length, size of the main, average crew weight, Hull & Rig weight and size of the spinnaker in question.
At the time I was working on what a Farr PY should be with and without. So without the PY should be 1071 (with a 70kg crew) but with a 12mtr kite it drops to 1067. Or say an RS400 which my system gave a handicap of 956 (with 2x80kg crew) but if you remove the kite (13.94sqm) it rises to 961.
Posted: 02 Sep 22 at 12:44pm |
Back in the day the difference between single handed full rig and singlehanded single sail Mirror was 0.5%. Bearing in mind skill levels and all the other variables then its probably neither here nor there, but if you are using VYC then I suggest 0.5, maybe 1 point at most. |
rich96
Joined: 20 Jan 05 Online Status: Offline Posts: 596 |
Posted: 02 Sep 22 at 1:57pm |
The RS 400 with/without PY numbers are way out An RS 400 with no kite would be lucky to beat a Scorpion/Finn similar on the water Planing spinaker boats are hugely handicapped when they cant use one. Only the heay ones that plane less are less affected (L2000, Wayfarer etc) The Farr numbers also dodgy - how could more than doubling its sail area have virtually no effect ? The system may need tickling ? |
Woodburner
Posted: 02 Sep 22 at 2:30pm |
Edited by Woodburner - 02 Sep 22 at 8:44pm |
Guests
Posted: 02 Sep 22 at 3:41pm |
Deleted in protest at censorship on here. Hadn’t posted in a while, won’t be again.
Edited by Peaky - 02 Sep 22 at 10:09pm |
Posted: 02 Sep 22 at 6:56pm |
The kite on an Asymmetric Canoe was worth under 4%, and they had monster kites, some 200% of fore and aft area. The real difference in round the cans performance is much less than people think. There's the "how long is it in use thing" as above, but add to that the actual speed increase available on a dead run is strictly limited.
